Question about Sportline Fitness Pedometer 360
Replace battery sportline 360 - Sportline Fitness Pedometer 360
Battery for a 340 sportline pedometer
The battery for a Sportline 340 Step and Distance Pedometer are any of the following: AG12, LR1142, SR1142, SR43 or 386 or equivalent.
Sep 20, 2012 | Sportline 340 Step and Distance Pedometer...
How can I tell what jewelers are qualified to replace the battery in my Sportline 900?
just bring it to the authorized retailer of your watch because they really know ho to change your watch battery
Jul 11, 2011 | Sportline Solo 900 Heart Rate Watch for...
Hello, I have a Sportline Digital Motion Sensor.
Do you mean the screen is blank or you cannot remember how to program it? Was it working perfect until you replaced the Battery?
Make sure the battery is inserted with the positivet side up?
Manual is here: http://www.sportline.com/manuals/370.pdf
Replacing the battery: 1. Unscrew the battery compartment cover on the backside of the unit using a small Phillips screwdriver and remove the cover. 2. Remove the exhausted battery from the unit, and insert a new battery (be sure to place the positive (+) side of the battery is visible, facing toward the battery compartment cover). 3. Replace the battery compartment cover on the battery compartment and fasten the screw (CAUTION: do not over tighten).
Dec 14, 2010 | Sportline 370 Traq Motion Sensor Pedometer...
How do you change the battery on the Sportline, fitness pedometer 360?
The battery hatch is at the bottom of the pedometer. Just slide the hatch open with your fingers and then pry battery out. Put in the new battery in the same orientation (positive up on most). I find shaking the pedometer works to get the battery to fall out. If my fingers don't move the hatch, I use a small flat blade screwdrivers.
I hope this helps.
(on my pedometer (a similar model) the hatch is on the back with a slot to slide in a finger nail and wraps partway around the hinge)
Aug 08, 2010 | Sportline 15 Function Total Fitness...
Sportline Fitness Pedometer 360 Manuals
you can email sportline and they'll send it to you if it's not already on their website
Jan 07, 2010 | Sportline Fitness Pedometer 360
Missing a battery for a Sportline Model 342 Pedometer.
Same problem here. If your pedometer is rectangular, with slanted window, LR 44 battery should work.
Oct 23, 2009 | Sportline Exercise & Fitness
I have a sportline 345 pedometer. I replaced the
I was looking for instructions for a different model when I found the instructions for the 347 here: http://www.sportline.com/manuals/345.pdf
Aug 07, 2009 | Sportline 345 Electronic Pedometer
the battery is under the front cover. the battery is a CR2032 button cell battery. all info will need to be re-entered. (stride, time, weight)
Mar 14, 2009 | Sportline 345 Electronic Pedometer
Sportline Fitness Pedometer 360 Logo
491 people viewed this question
Top Sportline Sport & Outdoor - Others Experts
Raymond Richards
Raymond Richards
Are you a Sportline Sport and Outdoor - Other Expert? Answer questions, earn points and help others
