Question about Dynex Voice-Certified PC Desktop Microphone
My Dynex webcam will not record sound. It use to but now it won't? What happen?
  • 5,603 Answers
Likely the volume got turned down or muted.
Try right clicking on your speaker icon in your tray and see if the "mixer" window comes up. Check for muting and volume levels in that window for the different audio devices.
If you can't find that window, go to the SOUND icon in the control panel and find VOICE input controls.
Posted on Sep 11, 2010
Dynex DX-24L150A11 won't turn on LED light is not on either
Sounds like you are missing your 5VDC standby voltage from the power supply. You either have a blown fuse or a defective power supply. Did this happen out of the blue or after a T-storm???
May 11, 2012 | Dynex DX-L42-10A 42 in. LCD TV
I HAVE A DYNEX WEB CAMERA AND LOST THE DISC,AND NEED TO REINSTALL IT,WHAT CAN I DO?
hi
go to following link you will have your web came drivers
http://www.topshareware.com/webcam-software-cd-dynex-dx-wc100/downloads/1.htm
Jul 30, 2010 | Dynex DX-WC100 Webcam
The sound wont work at the same time with picture
You may be using a laptop with a mic as well as having a webcam with a mic.
Try setting the webcam mic as default.
Vista
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure webcam to your chat program
Jun 09, 2010 | Dynex DX-WC100 Webcam
Screeching sound only when trying to record using LiveCam! and my
Sounds like you have another microphone connect at the same time as your camera mike and it is causing the feed back.
Or the second thing that could cause the feed back is that you have your speaker volume turned up to high.
Hope this is of some help. Bud
Sep 21, 2009 | Logitech Webcam
My green light won't go off on my dynex webcam
It sounds like your webcam software is hanging on to a program somewhere, and the chat program thinks its already in use.
This is unusual, insomuch that the webcam continues to transmit - almost as if its being forced by another program.
I always disconnect and re-connect the webcam to reboot it before going into chat, but its never had the light on.
Have a good scan of your programs to ensure you have no redundant webcam software creating conflicts.
I would suggest you uninstall the software - disconnect the webcam and install new software
http://www.dynexproducts.com/pc-692-10-dynex-13mp-web-cam.aspx
Aug 26, 2009 | Dynex DX-WC100 Webcam
USB ports/Driver downloads with dynex 1.3 webcam
download the driver from this page where also you find some documentation that can help you
Sergio
Jul 02, 2009 | Dynex DX-WC100 Webcam
I have a dynex web cam, I can't get it to run
you might disable the usb port? or just go to the control panel and go to add hardware then just click detect hardware
Jun 30, 2009 | Dynex DX-WC100 Webcam
Dynex webcam, built in mic won't work on msn.
I have a different Webcamera, but this should work. Please rate/vote me if it does! Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
Apr 20, 2009 | Dynex DX-WC100 Webcam
Dynex Voice-Certified PC Desktop Microphone Logo
166 people viewed this question
Top Dynex Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Dynex Audio Player and Recorder Expert? Answer questions, earn points and help others
