Question about Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300-EZ1524 no longer charges. The jack seems ok (it's firm, not loose, and it is not pushed in). When the power cord is plugged in the light does not come on -- it no longer seems to charge. Does this sound like I need a new cord with transformer? Or some kind of internal problem like with the motherboard? thanks.
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 18, 2010
Battery not charging
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Apr 18, 2011 | Toshiba Satellite Pro L300 Notebook
My toshiba satellite l300 suddenly not charging. might be the loose power jack, battery or the charger... how can i check which of these is the root cause?
Does the laptop work on the ac adabpter? If it does, you probably require a new battery. Ebay will be the cheapest source of original and copy batteries.
If it doesn't, you probably require a replacement ac adapter, Ebay again.
Hope that helps.
Jan 20, 2011 | Toshiba Satellite Pro L300 Notebook
My laptop turn off itself while loading
You may have a loose DC jack:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 05, 2011 | Toshiba Satellite Pro L300 Notebook
TOSHIBA SATELLITE PRO L300: PSLBDG : PROBLEMS: 1) Restarts automatically when i plug in the power cord. However works fine in Battery. 2) Shuts down when i try to install graphics driver after a clean...
Replace the AC Adapter, (ebay from £10.00).
Did it come with XP on it? Mine came with Vista and there are conflicts with XP and graphic adapters. There is no XP driver for the ATI adapter in mine.
Go online to Toshiba and download all of the updated drivers that you require. A user friendly system.
Dec 22, 2010 | Toshiba Satellite Pro L300 Notebook
My laptop wont charge, why???? It was charging two days ago, i plugged it in today and the charging light came on but then immedietly went off. Help!!
sometimes the heavy cable to the actual transformer becomes loose, it looks connected but isnt, try shoving it in firmly, maybe also look and see if its power light is on, if not change the fuse in the plug.
Mar 15, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L300 Will not start
I have had a this few times... what happens is the Contacts on the Socket for the power supply comes away from the Motherboard. Subsequently, it will not charge, nor power on... & then the battery gets so flat that it stops it all from working... You will have to get it repaired, it is a bit of a mission. & sometimes the damage done to the Motherboard precludes repair. So get a firm "Quote" from a reputable service center/man.
Feb 03, 2010 | Toshiba Satellite Pro L300 Notebook
Laptop will not turn on
Certainly sounds like a faulty charger , crazy as it sounds checked the fuse? or replace charger.
All else can be is liquid spillage or dead MOBO
hope this helps
Jun 10, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 Notebook Logo
131 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
