Question about Dryers
How do you change the belt - Dryers
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor or belt and if you have a front loading machine:
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Posted on Sep 11, 2010
I have a daihatsu mira 2008 car. Is there a timing belt or chain in this and when do I need to change this
Belt
Daihatsu timing belt change interval Questions & Answers (with ...
www.fixya.com > Forum > Tags > timing belt change interval
...timing belt on my charade having 67800 Km since i never replaced it manual says 10000 Km. thanks Andrew malta INTERVAL IS 80.000 KM OR 5 YEARS. ... when I have to change the timing belt for daihatsu materia 2008 Should be change out every 60,000 miles, this is an interference engine, if timing belt failure, there ...
Replacing Timing Belt ' Daihatsu Drivers Club UK
www.daihatsu-drivers.uk/node/81 Replacing Timing Belt. Replacement Interval Guide Daihatsu recommend the raplacement of the timing belt for the Sportrak every 60,000 miles although you must take into consideration the service history and the mileage into account.
daihatsu mira 2008 mileage to change timing belt Google Search
Mar 10, 2018 | Daihatsu Cars & Trucks
How to change a belt on sewing machine
Google is your fried in such cases Mary :>) I can probably find you your manual if you give me the model number.
  • How to Replace a Sewing Machine Drive Belt - YouTube www.youtube.com/watch?v=8Voq7f5vT6E
    • BY SEARS PARTSDIRECT
    • 1 MIN
    • 23K VIEWS
    2015-04-23 · Video embedded · ... shows how to replace a broken drive belt in a sewing ... a broken drive belt in a sewing machine. ... to Replace a Sewing Machine Drive Belt
  • Brother Sewing Machine Diagram to Replace Belt ? ' Yahoo ... https://answers.yahoo.com/question/index?qid=20090426184749AAQ5W2y
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2009-04-26 · Best Answer: I am sure there are the diagrams you are looking for are online. ... After years of machine maintenance I would love to have a duplicate ...
  • Videos of how to change brother sewing machine belt bing.com/videos 2q==Click to view 43:10HD Brother PE770 repairs, motor belt.(Spanish Discription) YouTube zClick to view 1:00HD How to Replace a Sewing Machine Drive Belt YouTube 9k=Click to view 1:03:43 SINGER 95-1 BELT REPLACEMENT & RE-TIMING 081813 YouTube 2q==Click to view 1:42 How To Install Antique Singer Sewing Machine Belts YouTube See more videos of how to change brother sewing machine belt
  • Brother PE770 repairs, motor belt.(Spanish Discription ... www.youtube.com/watch?v=Cy-wNw8_kuU
    • BY VINCE J. ARCURI
    • 43 MIN
    • 25K VIEWS
    2013-05-19 · Video embedded · Brother PE770 repairs, motor belt. ... In this video I am showing how to access the machine's motor drive belt. ... Brother Sewing Machine ...
  • Can U Help Me Find A Diagram to Replace Sewing Machine ... https://answers.yahoo.com/question/index?qid=20090428210336AAvwslh
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2009-04-28 · Can U Help Me Find A Diagram to Replace Sewing Machine Belt ? ... I can get a Diagram that can show me how to replace a belt on a Brother Sewing Machine ...
  • Replace Belt ' Brother support.brother.com/g/b/faqend.aspx?c=eu_ot&lang=en&prod=mfcl8850... Replace Belt. Follow the steps ... Close the front cover of the machine. Reset the belt unit counter. Press (Settings). ... please contact Brother customer service:
  • How to Replace a Sewing Machine Belt ' eHow www.ehow.com > Crafts > Sewing & Textile Crafts > Sewing
    • BY RUTH O'NEIL
    How to Replace a Sewing Machine Belt ... When you smell this, you know it is time to change the belt. Changing a sewing machine belt is fairly easy; ...
  • Sewing Machine Belt Sizing - Sewing Parts Online ... www.sewingpartsonline.com > Home > Maintenance & Repair Home Maintenance & Repair Sewing Machine Belt Sizing. ... How to Replace Sewing Machine Gears December 5, 2010. How To Replace A Sewing Machine Motor May ...
  • Brother Sewing Machines and Accessories: Rubber Drive Belt https://www.brothermachines.com/sewing/491/Rubber_Drive_Belt Brother sewing machines, parts and accessories ... Brother Emb. Cards; ... Home Sewing Machine Rubber Drive Belt
  • Sewing Machine Belt - Sew-Classic shop.sew-classic.com/Belts_c3.htm Click here to download for FREE How to determine the correct belt size and how to adjust/install a sewing machine belt. ... Sewing machine motor belt ... Brother Elna ...
  • Sewing Machine Repair Tips: Change / Replace The Belt on a ... sewingmachinerepair.blogspot.com/2008/01/change-replace-belt-on... 2008-01-27 · Although it may initially look complicated to change the long leather belt on a ... brother sewing machines. April 27 ... cover over the belt on the sewing ...
  • http://www.bing.com/search?q=How+to+change+brother+sewing+machine+belt+&qs=n&form=QBRE&pq=how+to+change+brother+sewing+machine+belt+&sc=0-42&sp=-1&sk=&cvid=B1D6E61981414EB7A56CB3A4C0D371A3
    Jun 18, 2016 | Brother Sewing Machines
    1996 Mazda Protege with 100,000 miles. Should the serpitine belt be changed? What is approximate cost?
    Drive belts are replaced every 5 years
    Your thinking of timing belts 80,000 miles
    Mar 08, 2011 | Mazda Protege Cars & Trucks
    I bought used Optima 2004 with mileage around 120k, i'm worried about the timing belt. Should I change it now? When should we make second or third change after the 60k timing belt change.
    to be on the safe side id change the belt every 55,000 to 65;000 miles make sure u change the belt tensioner as well they fail more than the belt
    Feb 23, 2011 | 2004 Kia Optima
    What is Ford's recomendation (mileage) for replacing the serpentine belt on a 1998 Ford Explorer?
    Theres no mileage to change just to check it, the way to check the belt is to look at the inside of the belt and you will see grooves in which the belt rides, if you see cracks in the belt then its time tom replace. the belt should be looked at every oil change it thats no time to check. hope this is helpful.
    Jan 22, 2011 | 1998 Ford Explorer
    I have 151,000 miles on my 2002 4cyl Camry and have not changed the timeing or the sepeitine belt: Is it time to have it done?
    Hi:
    It is overdue time to change your timing belt and waterpump, as you are on borrowed time on the timing belt. The waterpump and tensioner should be changed along with the timing belt, as they can ruin a new timing belt if they fail. Your serpentine belt should be inspected and replaced if needed too.
    Mar 24, 2010 | 2002 Toyota Camry
    Peugeot Expert Van Cambelt change
    Most cam belts need to be changed every 60,000 miles. I would change again somewhere around 126,000.
    Oct 28, 2009 | 1991 Peugeot 405
    When to change timing belt on 2004 honda civic
    Honda reccomends timing belt change at 100k. Most Honda dealers like you to change the belt at 90,000 miles (90k). some auto repair places will want to change the belt at 60k but that is not necessary (Note: if in a severe cold or hot climate like florida or canada you would change the belt before 90k or if the belt is over 7 years old.. Good luck:
    I’m happy to help further over the phone at https://www.6ya.com/expert/gregory_8e6ba270263743ac
    Oct 01, 2009 | 2004 Honda Civic
    Dryers Logo
    Top Dryers Experts
