I GOT MITSUBISHI DLP TV MODEL # WD-62525. I FOUND BROKEN LAMP,REPALCED WITH NEW ONE. TV DOESNT COMES ON AND TIMER LIGHT BLINKS. PLEASE ADVISE ME HOW TO SOLVE THE PROBLEM. ARAIN
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you are sure that the lamp is fine then the issue is with the ballast going bad and should be replaced, ballast is the power supply source for the lamp and should be replaced when it goes bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 11, 2010
  • 905 Answers
Hello Arain,
When the light went out (broke), it may have damaged the inverter as well. Put a call into your source for the bulb, they should carry the inverter as well.
Failing inverters are not uncommon, but they can also be affected by power surges as well. You might have the power supply checked out, make sure it is working as it should be.
My Mitsubishi tv model wd-62525 not on the light of timer is linking
If one light is blinking (lamp light?) remove and inspect lamp to make sure it is in correctly and not shattered. If the set has a recessed reset button on front (if set is unplugged and plugged back it should blink green for about 70 seconds and go out) you may have a issue there.
The model indicated here has a host of problems.
May 20, 2012 | Mitsubishi WD-62525 62" Rear Projection...
I have WD 62525 timer blinks very rapidl but wont turn on or off
HOwdy;
Try unplugging TV from a/c for 2- 3 minutes. Plug back in, turn TV on. If red light turns on (Lamp may light and go out) suspect bad lamp part # 915P020010.
Good Luck, Big Irish.
Nov 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd62525 replaced lamp still no picture
If Fans are OK and color wheel is running then it is the Ballast Board Call Encompass Electronics or visit website 1-800-638-3328 they will have part number and price I found Ballast board for my DLP for only $65.00 on E-Bay Depends on who has what for sale.
Oct 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv totally black, with the red light of lamp on.
sounds like the 34 error which is caused by the power board capacitors. you can get the repair kit that should repair that issue. The kit contains the replacement capacitors and step by step instructions. Heres a link to the repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jul 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replaced lamp, no picture, turns to red light
please make sure to place Lamp Door/ Cover after installation of new Lamp in TV.
Jun 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Lamp Light flashing Yellow
double check the lamp.make shure the 2 wires were installed correctly.Also check the plug inside the tv where the lamp plugs in.They have a nasty habbit of coming loose.
Jul 17, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
