Question about Fisher and Paykel Washing Machines
Husmart drive 5.5 no response at all when power turned on
  • Fisher and P... Master
  • 713 Answers
Hi hughnwendy, Just read your posting.Now,I need to know the model number of your machine,it is located on a sticker at the back of the machine,top left.Normally when the machine does not power up it means either there is no power at the power outlet or your drain pump is open circuit or your control module is faulty.Please reply with model number and I will guide you throe the testing of the pump.Looking forward to your reply.
Posted on Sep 11, 2010
What is the expected life span of a power supply 633195-001?? Second one in 1.5 years has failed!!!! Is it possible to get one on warranty. S/N 3cr3120h5k????
Approximately 5 years if no problem arises on power source and devices connected with it. Usually if the power does not come on you have to check fuse inside the power supply. It might got a power glits
Dec 02, 2015 | HP Pavilion Slimline S5-1554 Desktop - 6GB...
Why does 97 miata headlight retractor stay in upright position?
Common problem with any brand of car with power headlights. Probably the motor. You could inspect the unit to verify that it moves freely. Check on the Miata forum.
Jul 29, 2014 | 1997 Mazda MX-5 Miata
I have a panasonic tv CT-34wx54j red light 5 blinks
The power supply probably has failed. The clicks indicate it is trying to start up but can't.
Dec 30, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
1500 Silverado WT Transmission Problem
Check the oil level in the transmission for one. run a fault code check as well
Mar 27, 2013 | Cars & Trucks
Car randomly dies while driving. Has terminal power but no throttle response.
well if there is no check engine light on you can pretty much rule out electrical. I would be looking more at fuel. That usually wont kick on the check engine. could be a fuel pump going bad
Dec 10, 2011 | 2003 Hyundai Tiburon
I would like to unlock the region code on my Samsung HT-X810 DVD Player.Can you help??
TRY THIS
1. Remove disc from tray.
2. Switch off player and unplug power cord.
3. Wait 30 seconds, then reconnect power cord.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. Turn off.
10. Turn player on then off again.
11. Player is now region-free.
Dec 25, 2010 | Televison & Video
Gateway 510X H Desktop will not power up
Yes, definitely. You need to change your power supply.
Jul 23, 2009 | Gateway 510 X (10272197) PC Desktop
No response from Monitor, Mouse and Keyboard
Definitely a "faulty" motherboard. If fans on PC do not turn, no lights come on and dead screen.
If lights come on, and fans turn, try to reset the BIOS by removing your CMOS (and setting the jumper to clear for about 5 minutes, then put the jumper to normal again) battery for 5 minutes.
Sometimes the bios just "stuffs" up and you'll get no response from your pc at all. So all you do is "CLEAR THE CMOS/BIOS"
Apr 16, 2008 | Dell Dimension 3000 PC Desktop
Mitssuisbihi ws 65869
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
Aug 25, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Washing Machines Logo
16 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
