Question about KitchenAid KSRG25FKSS Side by Side Refrigerator
My icemaker has been tempermental for months now. It will make ice when it feels like it, which is not very often now. I figured out that if I run water through the door until it is warm, it will make one dump of ice in about 5-10 minutes, then I have to wait about an hour or so and do it again. Now, that's not even working; the "bars" are stuck in the upright position and won't move and the red light flashes whether I have the switched set to on or to off.
  • KitchenAid Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 11, 2010
GE Profile REfrigerator: Model PFSS6PKWASS Problem with loud clicking coming from icemaker every 2-3 seconds. Will do this for 30-60 minutes constatntly, then will stop clicking for the same period of...
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
Jan 25, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker is not working
ok one of the first steps is to make sure your getting water inside the ice maker feel with one of your fingers if you can feel ice or water on the inside of the tray if you have ice then you would have to disconect and remove the ice maker fromthe machine and run hot water to clean out the ice build up on the inside then reinstall the ice maker back into the machine and test for 24 hrs to see if you get ice if you dont then you have to replace the icemaker. If you do not have any water going into the icemaker water tray then you would have to check the water valve located in the rear of your machine if the water valve is not bringing water to the icemaker replace the water valve hope this helps
Jul 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice cube maker not making ice
feel with your finger on the inside of the icemaker to see if you have water or if there is the presence of ice if you have water or ice on the inside of the ice maker then replace the icemaker if you dont have water or ice then check the valve in the rear of the machine to see if your getting water to the icemaker
Apr 29, 2010 | Maytag MFI2568AE Side by Side French Door...
Ice Maker has stopped working....not sure if water is reaching ice maker. Would this be a difficult fix?
Depends. Put your fingers into the icemaker. Feel for ice or water. If none, check the fill tube to ensure it is not iced up. This tube feeds the icemaker with water. If it is iced up, thaw it out. If no ice or water in icemaker then pour a cup of water into the icemaker, wait the nite to see if it drops the ice. If it does the problem is the valve behind the frig.
Feb 08, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker issues - what to do next?
I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My icemaker was working at one time but now is not working .. I can feel the ice inside the icemaker unit.
Often these icemakers just get jammed because the ice cubes stick together. Carefully dislodge all of the existing ice and it should be ok
Jul 31, 2009 | Frigidaire FRT17G4B Top Freezer...
Icemaker stuck in 'vacation mode'
Feel inside the ice slots are there any old cubes that have evaporated in time? Take the ice maker out and clean it up and place it back inside to see if it will fill with fresh water. Take a hair dryer and melt the old ice inside the slots and see if it will try to fill. I will wait for a response from you.
KSCS25INWH00 Kitchenaid Parts
APPLIANCE 911
KitchenAid Refrigerator Ice Maker Assembly 2198597
May 06, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
Mar 10, 2009 | Fisher and Paykel E522B Stainless Steel...
Whirlpool icemagic
fill cup of the icemaker is frozen, take your finger and feel in the little white square cup at the rear of the ice maker, if you feel ice in it then thaw it out wit a hair drier and you are good to go
Apr 08, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker not working
It is under warranty, please call for service before it runs out!
Jan 03, 2008 | Refrigerators
KitchenAid KSRG25FKSS Side by Side Refrigerator Logo
82 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
