Samsung 40 inch TV -- the information from the Info Bar flashes up on the screen interrupting the picture momentarily. Sometimes it does it quite often- other times it may happen 20 minutes apart. I have tried changing the picture ratio and also changing the time and date (both of those are on the info bar). but to no avail. Can anyone help me or should I look elsewhere?
  • 6 more comments
  • audreycweber Sep 11, 2010
    Why would this suddenly begin happening? I have had the set well over a year now and it just started happening a month or so ago. I don't know the answer to your question, but will check with my son in law when he gets back in town tomorrow night. He is the one who hooked it up
    Yes, we are hooked up into a cable box and nothing has been changed.
    Thanks for your comment == I will check it out.
    Audrey
    The previous expert suggested my cables were at fault however, we have not changed anything since we first set it up, and that was over a year ago.
    Any other suggestions out there? My source is cable from Time Warner and we recently added a DVD player --
    Thanks
    Audrey
  • audreycweber Sep 13, 2010
    I would have no idea of how to do what you suggest. Should i call in a repair service or is there some thing that I could do considering that I do not have any technical experience?
    Audrey
    This solution is not possible for me since i do not have any experience in self repairs.
    Is there any way to shut off the information bar completely?
    I am not sure -- my family did not keep anything that would tell me that when they set this up -- however, the did keep a strip that has this information: LED TV , Series 6000 <6 Luxia.
    Does this tell you anything?
    I dowloaded page 36, it says nothing about upgrading firmware (what is firmware?). Page 36 refers to Media Play Function.
    When I click Firmware,there doesn't seem to be anything that I ca use.
    Thanks again -- Audrey
    I have tried working with the info on page 33 -- I will let you know what happens -- haven't had time to sit and watch tv in that room. Thanks again
  • 4,472 Answers
First off can you give me the exact model of the television then I will be glad to assist you further.
Thank you,
Lee
Posted on Sep 13, 2010
  • 17,129 Answers
This a fault that has occured from the OSD (on screen display).
This is the information that is provided by the microprocessor and is displayed. The clocking/positioning also comes from the processor and the associated circuts.
So sicne you find this as erractic, just check for capactitors near the microprocessor to be defective. Solder around the sections in the mP , check the crystal and change suspected low value electrolytic capactiors.
If not the mP can be faulty.
Posted on Sep 11, 2010
  • Donald DCruz
    Donald DCruz Sep 13, 2010
    Yes, it would be good to take an opinion than to look into without any technical knowledge.
  • 736 Answers
I can help you but I need a little more information perhaps. Are you using a cable box or a satellite receiver? Most often when I hear about this happening a cable box or satellite receiver is connected to a television with a coaxial cable (reminds you of a water hose). This type of connection is not sufficient and you will have to use a composite (RCA) or component cable instead. Perhaps you are already using one of those cables as well as the coaxial cable. That means when the television was connected to the device it was connected to the television in more than one place. If this is the case you may be on the wrong input. You may be on the input for the television's tuner when you should be on one of the hd inputs. Hope this helps.
  • Loretta Northcutt
    Loretta Northcutt Sep 11, 2010
    I recommend printing out the solution I posted and completing the troubleshooting. The tv has to be on the wrong input.
  • Loretta Northcutt
    Loretta Northcutt Sep 14, 2010
    I really don't think it's firmware. If the television is on the tuner input and the cable box is connected to the television with a coaxial cable then the information bar will keep popping up on the television screeen.
    The television needs to be switched to the input that the componenet cables are connected in (or the one the hdmi cable is connected to).
    If this is a cable information bar and not a television information bar then the cable box probably needs replacing.
    The manufacturer should be able to walk you through a factory reset going through the service menus to "reboot" the television if it turns out that I'm wrong. They should be able to send you the firmware as well. Sometimes after installing the firmware the television needs a factory reset. No there is no way to just shut the information bar off.
Samsung un40eh5000f led backlight don't work i replaced power supply and main board still no luck
Troubleshooting the Samsung LED TV Model UN32EH4003 ...
? 2:46
https://www.youtube.com/watch?v=2TImpsUnGtI
Jun 25, 2013 - Uploaded by George Droukas
Samsung TV troubleshooting, In this video you will be able successfully ... where can I buy the power supply board? the ledlight doesn't light up so it .... The second port was still fully intact but also not working, I was able to get it .... which turns onbacklight (BLU_on) and turns on the power supply (PS_on).
Samsung UN40EH5000 Review; 40-inch LED TV, (also ...
reviews.lcdtvbuyingguide.com/samsung-lcd.../samsung-un40eh5000.ht...
The EH5000 is Samsung's lowest end line in the larger size LED backlit LCD TVs for... 60Hz refresh rate doesn't handle judder sports programing and gaming as ... take advantage of the resolution, giving you more work space on the screen.
Samsung UN40EH5000 40-Inch 1080p 60Hz LED TV
www.amazon.com/Samsung-UN40EH5000.../B00723...
Amazon.com, Inc.Samsung UN40EH5000 40-Inch 1080p 60Hz LED TV (2012 Model) ... Samsung didn't advertise this (or maybe its just my TV), but I have absolutely NO BACKLIGHT BLEED...... Hope that helps you find the settings that work best for you. ..... Game Modedoesn't really do anything except make the picture darker and less ...
Jan 05, 2016 | Samsung 40-inch LED TV - UN40EH5000FXZA...
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Gray bar on top only
Hello, I will need a picture of the screen and a model number to be sure, but it sounds like it has a bad screen.....tks...Terry
Mar 22, 2014 | Samsung Televison & Video
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Jan 20, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
I have a 40 inch Samsung -- the info bar keeps flashing up on the screen, interrupting the picture.
that is a cause of static from the main board due to accumulation of dirt and stains cleaning the mainboard will solve the problem.
To do this unplug the TV open the back cover and you can easily acces the main board use a paintbrush to remove the dirt specially on the quad pack IC thoroughly clean the pins of this IC be careful not to apply excessive force it will broke the pins connectors.Use a thin pointed tool to pick the dirt in inbetween the pins of the IC..good luck hope this helps.
Post back a message if you have other question or if this solution didn't help..
please do click the tumbs up button for my rating! Thank you
Sep 11, 2010 | Samsung Remote Control
New samsung 40 inch LCD. When in the wide mode
if you are watching cable or satelite, you need to change the screen format output from the source to make sure it matches with the TV
Jun 14, 2009 | Samsung LN40A550 LCD TV
Loss of picture on Pioneer Plasma Tv
i have a pioneer 43 inch bought in 06. tv wont turn on light flashes red the light means standby. what does this mean
Jun 07, 2009 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
