Question about Dryers
Need to replace element, switch and thermostat on Kenmore Elite Oasis 110.67042600 dryer...but don't know how to remove the panels or which panels to remove.
    President:
  • 3,074 Answers
Remove the front panel and you will be able to access everything. Unplug the dryer,open door and remove all screws, with a flat tip screw driver pry gently on the top corners. Gently move the panel forward and disconnect door switch. sit panel aside and lift top up and back, it should rest on its clips. then heating coil is in the back right corner. Good Luck Tim
Posted on Sep 11, 2010
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
Dryer does not heat correctly code F31
The thermostat which is a round 2 wire control on the blower box on the back of the dryer controls the heat on all dryers. always shut off power when checking any electrical appliance. Clothes dryers are wired with 2 voltages, The 240 volt supply is for the heating element only, while the 120 volt supply gives power to the timer and motor that spins the drum and powers any lights and switches. If the heating element is coming on, try replacing the thermostat. As always unplug the dryer first.
Dec 05, 2013 | Kenmore Dryers
I have a kenmore elite dryer model # 11070952990 that will not heat up, I replace the glow bar ignitor, I don't know what i'm missing.
Check the thermal fuse. You can temporarily bypass it by hooking its two wires together then see if it heats.
Sep 24, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
Need diagram of kenmore oasis HE
Do you have a wiring diagram for the heating element for a kenmore oasis dryer
Mar 27, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I need the installation manual for a Kenmore Elite Oasis gas dryer. Specifically I need to know what water line attaches to the dryer (for steam), the hot or the cold?
Hello, Here's the link to view the owners manual and exploded view of the parts for your model. Once there, click on the exact model # you have (it's listed on your dryer's data plate) so you get the right one.
http://www.managemylife.com/mmh/owner_manuals/search?query=kenmore+oasis+elite+dryer+7808
Mar 09, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Kenmore Elite Oasis dryer will not heat.
check the element by removing the back panel look for a break on the metal spirals replace if necessary.
Sep 17, 2009 | Kenmore 67082 Electric Dryer
Need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Dryers Logo
120 people viewed this question
Top Dryers Experts
