Question about Lowrance LGC-2000 GPS Unit GPS Receiver
I need a 25' Y-adapter extension cord to connect my LGC-2000 to my Lowrance LMS-33o c unit. Are they available?
  • 13433 Answers
SOURCE: Lowrance LMS 335 C
Heres the update
http://www.lowrance.com/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-335C-DF/Downloads/LMS-335C-DF-Software-Update/
Posted on Aug 04, 2008
SOURCE: Lowrance LCX-15MT Ihave used this
Go to lowrance's website and run through their set up tutorial / instructions for the unit, there is also a software upgrade you can do online for the unit.
Posted on Oct 10, 2008
hydetech
  • 113 Answers
SOURCE: My Lowrance LMS-337c df keeps going crazy.
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}This could be caused by glitch in the operating systemsoftware or by low voltage due to a short in the unit or somewhere in the boatswiring. To troubleshoot the problem Iwould recommend the following steps.
  1. Try a soft reset
  2. If the problem resurfaces, try a hard reset
  3. Update the the operating system software
Soft Reset (Does not delete GPSData)
1. Turn unit OFF 2. Press and holdthe PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map
Appears
Hard Reset (Deletes stored GPS Data
such as Waypoints and trails)
1. Back up any waypoints, routes,and trails that you want to save on a blank MMC card
2. Turn unit OFF
3. Press and hold the ZIN&ZOUTKeys at
the same time
4. Pressand hold the PWR key
5. Release both buttons when the USAmap
appears
To update the operating system software, check out this link:
Lowrance337c df update
If you don't have a card reader I can program an update card for you.
Posted on Dec 16, 2008
SOURCE: i just bought a lgc
hi the lgc has to be powered also with the nmea cable,red to+,black and shield to-,you also need a 60ohm terminator atached to the short length coming from the y piece,the manual does not state this very clear and lowrance is not much help
Posted on Feb 10, 2009
SOURCE: Power to Lowrance GPS
Yes you have to hook up the red wires together to the + and both black ones to the negative, otherwise the antenna won't be supply in current , and don't forget to insert behind the red wire a fuse and a switch to avoid to discharge your battery .
Bernard.
Posted on Apr 26, 2009
Lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
Lcx-15ct (gps module not responding)
Before you give up on the LGC-12S you have now though, try plugging the LGC-12S right into the LCX-15CT without an extension cable. If the module not responding goes away...you just need a new extension (GPSX-25G p/n 99-46).
The power cable has a set of yellow, blue, orange, and bare data wires. If these wires short together, you can get the module not responding error.
If all that doesn't help...the LGC-12S is bad.
The LGC-12W p/n 112-06 will work with the LCX-15CT. You probably get this at many marine electronics dealers or go to lei-extras.com and buy it straight from Lowrance. They cost $229 so you might want to shop around putting that money into a whole new system altogether.
Make sure you have the latest software updates if you get the newer LGC-12W. These can be downloaded at http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Let me know if you need more help.
Jul 10, 2009 | Lowrance LGC-12S GPS Receiver GPS Receiver
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
HAVING A PROBLEM WITH MY LOWRANCE 525C WITH EXTERNAL ANTENNA. IT KEEPS TELLING ME GPS MODULE NOT RESPONDING. I HAVE CHECKED ALL CONECTIONS AND CANNOT FIND A PROBLEM. WHAT NEXT
Make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version LMS-525, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display.
If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshooting guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
If this doesn't tell you anything, most likely the GPS module is bad.You will need to contact Lowrance support to get it repaired/replaced. You can call them at 800-324-1356 or email them at http://www.lowrance.com/en/Support/Product-Support/Contact/
Jun 29, 2009 | Lowrance Lms 525c Df 5" Df Sonar...
Alarm says" gps module not responding"
"GPS Module Not Responding" is the display units way of telling you there is basically no GPS module connected. You didn't say which unit you have, so I am assuming this is something like an LMS-520? The GPS module is the LGC-3000? If this is the module you have, make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display. If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshootin guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
Apr 05, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Bernard.
Jan 25, 2009 | Lowrance LGC-2000 GPS Unit GPS Receiver
Lowrance LGC-2000 GPS Unit GPS Receiver Logo
607 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
