Question about Stanley Air Tools & Compressors
Loosening air out of triger - Stanley Air Tools & Compressors
  • 2,176 Answers
You need a new trigger valve assembly, there is an o ring inside that has cracked. Usually the part number for this is a TVA6. Let me know if you need more assistance
Posted on Sep 11, 2010
How do you fix/repair 15 guage nail gun o-ring for the nail gun triger. air is leaking from the triger
the trigger assembly would need replaced. I have detailed instructions in the tip section on the removal and installation of the trigger valve. Let me know if you still need more assistance.
Jul 07, 2011 | Stanley Bostitch Nail Gun
Its a Brand new gun and when I **** it the trigger will not set so the gun will not fire
the fault is the triger return spring,,,,,,,get it looked at,,,,,
by a gun smith,,,faulty triger are dangerous,,and killers too?
Aug 27, 2010 | Beeman 1024 Takedown Rifle, Scope, Rings &...
How do i fix my triger leaks
Unfortunately, trigger leaks are only fixable by replacing the trigger mechanism. Can you update this with the make and model? I should be able to direct you to a parts location. Trigger assemblies usualy run around $20 or so.
Dan
May 20, 2010 | Air Tools & Compressors
Hi, The socket adapter spins before i engage trigger
The seal is bad inside leaking air pressure to the gun without squeezing the triger. Get a reseal kit from Sears
Jan 22, 2010 | Craftsman Tools 1/2" Air Impact Wrench...
Beeman air rifle wont latch when cocking
you have a triger fault its not locking the piston back best and safest bet is a gun smith,, never play with a triger if your not good with guns,
Dec 25, 2009 | Beeman 1024 Takedown Rifle, Scope, Rings &...
How do i remove the bolt from the mossburg 308 win. and is there a product you offer to modify the triger
if i were you i would leave the bolt alown,,its a hell of a job getting them back in,,,as for the triger i know there a bit on the heavy side to pull at nearly 4 lbs but its a safe pull,you could drop the gun into a gum smith and get him to snip off a coil off the triger pull spring,,and stone the sear,, but be warned it will make the triger twitchy,,you realy dont wont to light a triger on a hunting rifle 4 - 6 lbs is normal
Nov 18, 2009 | Optics
Triger dont wokr
try lubricating it with air tool oil, put ten drops in at the air nipple, try tapping unit on table as you press trigger in and out.
Aug 17, 2009 | Ingersoll Rand 1/2" Super Duty Air Impact...
Piston drives down when hooked up to air...piston does not return up. is this a problem with the triger valve? I am not pulling the triger, just hooking up the air. This gun hasnt been used in 10 years,...
Sounds like the head valve is stuck in the head. Take black head off and see if the valve is spring loaded by pushing down and see if it comes up. This is the usual problem.
Jul 08, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
BOSTITCH AIR POWERED NAILER - AIR LEAK THRU TRIGGER
sounds like the rubber seals have dry rotted prob from not oiling it enough, but you should be able to go on the Bostitch web site and order new rubber seals for the gun
Sep 29, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
47 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
