Question about Refrigerators
The freezer motor fan had an ice build up on it. Then it stopped.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Sep 11, 2010
Noisy fan in freezer stops when refrigerator doors
bad evaporator fan motor or fan motor blade or ice build up that is building up by the evap. motor or evap motor blade.
Oct 10, 2014 | Refrigerators
GE Profile refrigerator Model # PFSF6PKXCWW motor is noticeably louder
if you are talking about the motor in the freezer the ice build up could be causing the fan to beat against the ice... could be a defrost cycle problem,,,, if ice is building up on rear freezer wall you have a defrost cycle problem and the ice is forminf around fan causing fan blades to hit the ice (loud noise)
Aug 28, 2014 | Refrigerators
Our 8 year old refrigerator has recently begun making a continuous tapping sound. The sounds stops when you open the bottom freezer door.
the compresor fan is might make that sound or the fan in your freezer is tuching something like build up ice... see if you can reach it and clean it.
Jan 01, 2010 | Refrigerators
My hotpoint ff187e fridge is not cold, the freezer is working but getting a build up of ice which i have defrosted. tried turning off. when i open the fridge does not feel cold,not sure if the fan is...
we had same problem,apparently there is no such thing as a frost free fridge/freezer, you have to turn your appliance off for at least 3 days because the freezer has a build up of ice which stops the fridge from working, you must leave it switched off for this time otherwise it will just ice up again.
Nov 09, 2009 | Jenn-Air JCD2389G Side by Side...
The freezer motor starts whenever I close the freezer door. It is loud and sounds like something is hitting a fan.
The evaporator fan motor inside your fridge is constantly trying to keep the temperature you have set it to. when the fan is on it circulates the cold air from your freezer in to your fridge. if you hear a banging noise it is cause by the fan hitting a build up of ice. this can be caused by a clogged drain pan or tube, not allowing water build up to be drained, or you could also have a defrost heater issue in which case you would have a large build up of ice near your fan. you can access the fan motor by removing the two panels at the back of the freezer, once removed you will be able to see whether or not there is a ice build up.hope this helps you
Thanks.
Oct 11, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice builds up in freezer, and vibration noise only when freezer is closed. When freezer open vibration noise stops. starts when pressing the switch which turns off the light.
Replace the fan motor AND blade . ( evaporator fan motor ) . This motor is located inside the freezer , behind the rear panel . The switch , is a fan/light switch , when closed , turns on fan , and light off . When open , light on , and fan off . normal operation .
Oct 07, 2009 | Amana Refrigerators
When doors are opened it stops. Ice is forming unnaturally in the
It sounds like you may have a bad evaporator fan motor or broken blade.
Another cause could be a failed defrost system component. The would cause a build up of ice and frost and the fan blade could be coming in contact with the frost or ice.
The fan stops running when the doors are opened on this model to prevent the circulation of warm air.
Sep 11, 2009 | Bosch Refrigerators
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Fan in freezer - evaporator fan?
HI. thanks for the question. yes the fan in the freezer must be replaced.and also the drain tube in the freezer, is clogged. cut power to the fridge. remove back panel . replace the fan motor . also clean ice build up. clean drain tube, from freezer to the drain tray, at the back, near the compressor. thanks the appliance doc. please rate my answer. thanks
Oct 07, 2008 | GE GTS22WCP Top Freezer Refrigerator
The freezer fan motor is not running, the freezer is not freezing and is not making ice
Check that there is no ice build-up stopping the fan.
Also your description of the fault is cut short, can you explain what it was meant to say?
Sep 30, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
