Question about Hitachi 53UDX10B 53" Rear Projection Television
I have a hitachi ultravision digital hi-def TV model number 53UDX10B from December 2001. The words in its own menu and from my cable box menu are distorted, as well as some words appearing in commercials, programs, etc, as if they are written double or triple over one another. I am using a Verizon Fios Hi Definition cable box connected to the TV through audio/video cables. There is no slot for an HDMI cable line.
  • Hitachi Master
  • 8,457 Answers
The tv problems known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.The shop,will cost $300-350 for parts and labors.
Posted on Sep 11, 2010
I would like to remove the digital display boxes at the bottom of my hitachi tv screen
If you are using a sat or cable box check its menu first to make sure where the display boxes are coming from.
If from the set usually just go to the indicated item in the menu and UnCHECK it.
A owners manual should be available if you do not have it either on the Hitachi site or by GOOGLE the model number with the word manual after it.
Mar 16, 2012 | Hitachi Televison & Video
I need to replace the lamp on my projection tv HITACHI ULTRAVISION 53UDX10B. it's difficult to find online. i will need to have the part number for the lamp.
Your model is the DP-15 chassis which is a CRT projection so you do not have a lamp like the DLP models do. You have three CRTs Red, Blue and Green instead of a single lamp.
Jun 09, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Apr 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Broken screens on 53'' Hitachi rear-projection TV
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
Oct 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
We have a 40" Hitachi ultra vision model # 42HDT52 plasma screen TV. We have never been able to remove the " written words" off the screen used for the deaf. We have comcast if you need to know that. Terri...
Closed Caption has to be in the menu on the set. Go under the Audio section, find CC and turn it off. This will be the same if you are using a Cable box. They also will have a closed caption setting.
Sep 18, 2009 | Hitachi UltraVision 55HDS69 55 in. Plasma...
Hitachi hdtv ultravision digital projection tv. #53udx10b. Issue: Blue halo around the body of people.
my picture is distorted and showing double. The characters are orange and I can't read the menu items because they are also showing double.
Sep 21, 2008 | Televison & Video
I have a Hitachi Ultravision tv model 53udx10b. I'm seeking the remote control code. Can u help? cole
Hi FixYa Problem,
I found a list of the remote codes associated with my internet provider's universal remote and kept changing codes until I found the one that solved the problem. Thanks for your offer, but I'm okay.
cmwallace42
Aug 01, 2008 | Hitachi Televison & Video
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi ultravision
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 04, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
241 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
