Question about Sewing Machines
Haven't used serger for a few years, got it out to sew now seems to be locked up, just moves very slowly if at all.
  • 161 Answers
I had a similar problem when i tried to use a friend's machine. i just oiled it to death and it worked fine. make sure to get the manual and do every spot, gently sew till it moves quiet freely. ( obviously make sure all the threads are free)
Posted on Sep 11, 2010
I have a brand new brother's serger 1034D.. Its new.. as in never been used but once but it's not in warranty. It's making a grinding noise. I've liked it and is clean. Any ideas what's wrong??
Could be that since it has set for years without use or maintenance, the old oil has dried out and the motor is straining to run the machine without sufficient lubrication. Trying to run the machine in its present condition could damage the motor. Your machine very likely just needs a thorough oiling (1-2 drops of fresh good quality serger oil) every place that metal rubs on metal. (Sergers usually take a lighter-weight clear oil--different from what sewing machines would use.) You should probably throw out the oil that came with the machine. It is probably old and should not be used in your machine.
A serger requires much more frequent oiling (the moving parts behind the front door, ie the looper mechanics, etc.) than a sewing machine. In addition, about every year I take the bottom off my serger and lube the moving metal parts inside with Tri-Flow Synthetic Lube. It has a whole different sound after getting some TLC!
To keep your serger operating for years, be sure to regularly clean and apply a couple drops of lube as recommended in the owner's manual (maintenance section).
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwj1woi47IzQAhUCwmMKHVVPCBQQFggtMAA&url=https%3A%2F%2Fwww.brother-usa.com%2FModelDocuments%2FConsumer%2FUsers%2520Manual%2FUM_PL_2100_EN_238.PDF&usg=AFQjCNF99J5PVNoFcHjv5FJcR-6eyNqTNg&cad=rja
Nov 03, 2016 | Sewing Machines
Singer QuantumLock 14T967DC has been sitting for a few years in storage. Turns on, but hums and won't move when pressing the peddle. Also, cannot turn handwheel. It's stuck. Any ideas?
It appears to be a mechanical machine.
If it has been setting without use or maintenance for several years, the oil has probably thickened and is preventing things from moving. Consult your owner's manual, page 64, clean and use fresh oil recommended by the manufacturer--apply 1-2 drops of oil each place. There are internal spots that should probably be oiled as well, which you may want your repairman to service. A hot handheld hairdryer directed into the internal mechanics of a sewing machine will help loosen old oil, so it may work on a serger too. Or, you can set the serger near a heat source, ie radiator or heater (not TOO close) for a period of time to give it time to warm up.
Jan 15, 2016 | Singer QuantumLock 14T967DC
I WAS SERGERING AND THE MACHINE COMPLETELY LOST POWER , WHAT SHOULD I LOOK FOR ?
First make sure it's still plugged in and that you haven't tripped a breaker. Temporarily move the machine to another area of the house. If you still have no power... take a good look and sniff at your foot pedal (smell burnt?) It may need replacing.
Other than that, I would recommend taking it in. Sergers are tricky and I would not recommend trying to service yourself.
Oct 27, 2012 | Sewing Machines
I need replace thread holder for Juki MO-644D serger
Good luck. I found a replacement part for one of mine on Ebay. Just search for Used Juki Serger for parts. Maybe you'll find a 644D for cheap enough that you can scavenge parts for a few more years.
Oct 25, 2012 | Juki MO-644D Mechanical Sewing Machine
Why is my serger going faster than normal
Most problems with a serger can be fixed with a few simple adjustments to either the needle or the serger tension dials.
Find helpful tips here ! before buying a sewing machine.
Sep 25, 2012 | Baby Lock Eclipse Serger
Related Tags: slow sewing stops lock not sewing Print Email Flag Problem with Baby Lock Eclipse Serger I have a Baby Lock Serger BL-90. When it has been on for a while and I'm sewing, it starts t
Perhaps was same as my problem.
Call your local service shop. Baby Locks in closets for years often have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Been there, done that.
Jul 02, 2012 | Baby Lock Eclipse Serger
Serger runs very slowly
it could be the serger it's self or the power cord or even the foot pedal
it would be a good idea to have the machine serviced
Jan 29, 2012 | Baby Lock Sewing Machines
I need to know how to oil a simplicity serger-easy lock-with differential feed
I have a Simplicity serger SL880 that was my mothers. She past away about 8 years ago. I was trying to use it but appears the motor may be locked up that moves the feed dogs. Is there a place to oil it? If so where? Thank you.
Apr 18, 2011 | Simplicity Serge Pro SW432 Mechanical...
Janome mylock 234 d
It may be rusted or a looper may be bent. Take it into a sewing machine dealer for service/repair.
Apr 20, 2010 | Janome MyLock 634D Mechanical Sewing...
Elna Pro 5DC Serger
Sound to me you should get it serviced. Your timing is off. It also could be your needle make sure you use serger needles
Aug 08, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
