Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Broken glass stuck... - Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
  • 377 Answers
About the least dangerous way of cleaning it out would be with a vacuum cleaner. You may have to break the glass up a bit to get the pieces small enough to pull into the hose or perhaps use the suction to hold the pieces to pull out of the unit. Last resort would be to remove the unit from below the sink and invert it to remove the glass. You would have to disconnect plumbing to do this, but it might be the only thing you can do. You could also find tools used to pick up dropped parts that operate with a claw at the end. They are about 18-24 inches long and certainly small enough to fit into the drain. You can get them at home stores for less than $10.
Posted on Sep 12, 2010
  • pwillitz Sep 23, 2010
    I am sorry you did not find my suggestion helpful in solving your problem.
  • CharlesG Nov 12, 2012
    Broken shot glass, got most of the pieces out with a tool like he mentioned, but it was still jammed. I did a search for the model of my disposal and broken glass and found this site where I saw the vacuum idea. I got my wet/dry shop vac and sucked up 3 larger pieces that I had missed, and of course smaller pieces, and when I tried it, it turned! I then sucked up any more that might have still been there and now it works perfectly! Great idea! I thought I was going to have to take it apart!
The broken light bulb is in my bath room wall fixture not related to auto
If you have a broken light bulb stuck in a fixture and the glass is shatterd, use a potatoe and press it into the broken bulb and socket. This will usually remove a broken bulb
Oct 18, 2015 | Cars & Trucks
Power button on iphone 4s stuck
Get a New Iphone 5.... All kidding aside, there are many repair shops that are popping up all over MALLS and around cities that you can find by going on-line. Monday, my friend John had the same issue and we went and had his repaired and his broken glass replaced for a grand total of $25 (including the glass) in Providence Rhode Island.
Jul 17, 2014 | Apple iPhone 4S
My VW passat 2001 model has passenger door electric window stuck. I can hear the motor running on the door. How can I fix this problem.
The window regulator or plastic tabs attached to the glass is likely broken and will need to be replaced, if you can hear the motor running but the glass does not move. If you're handy with fixing cars, you can purchase a window regulator and change it out fairly easily by removing the door panel and swapping the regulator out. If the plastic tabs on the glass are broken, you will have to take it to an auto glass shop to have new tabs replaced on the glass.
Jan 20, 2011 | 2001 Volkswagen Passat
I need to know how to install the mirror glass on 2007 tahoe on passenger side and the housing is in good shape I only had the glass to break.
The new mirror glass simply "Sticks" or sometimes "Glues" into place. The trick is getting the old glass off without destroying the mechanism that it is stuck to. Carefully use a flat blade screwdriver to pry the gum/glue under the glass to get all the broken pieces of glass out. Be careful not to pry in such a way that the plastic frame that it sticks to gets pried forward because you will strip the gears that hold it in place.
Jan 11, 2011 | Chevrolet Tahoe Cars & Trucks
Broken Qtr, Glass How do I replace it?
You will have to remove the trim around the glass and clean up every piece of broken glass. Then, scrape all the sealant material and remaining broken glass stuck on the frame and put new sealant material on the frame. Lastly, replace the trim and place a few pieces of tape to temporarly hold the glass on, while the sealant cures. Sounds easy enough but it can inflict lots of cuts and scrapes as well as become messy. Good luck.
Sep 28, 2010 | 1997 Pontiac Grand Am
My glass top has a broken in the corner on my jgp932 cooktop range can i just get the glass top replaced and can i do it myself
I'm sorry to hear this. you can get just the top, but your lookingat somewhere between 300-700 dollars just for the glass. also this is not a common part and will probably be back ordered, so you'll be looking at a wait of 2-5weeks for the part. you can change it yourself but due to the cost of the glass I would have a service company change it so that if it breaks while changing they will have to pay for a second one and you wouldn't be stuck having 2 broken glasses
Apr 23, 2010 | GE 30 in. Profile JGP932 Gas Cooktop
Keeps stating remove paper from platen glass before copying when trying to use the feeder. Nothing on the platen glass.
First you must lift the dadf all way up, because (from front looking) on left side under /by dadf hinge is white flap.This flap registers the lifting and pulling down of dadf.Probably is only that.
...but check if its broken or stuck,...
Or you have broken sensor or some part in sensors, or piece of paper, or similar in dadf
Feb 18, 2010 | Canon ImageRunner 2020i Copier
Rear hatch is stuck closed possibly from broken glass in lock mec
Removed the inspection cover for the lock mechanism on the inside of the back hatch and used a screw driver to manually unlatch the door while someone else was pulling on the handle. It turned out there was a lot of glass around the pocket where the lock mechanism was possibly binding the lock
Jan 04, 2010 | 2003 Honda Pilot
Broken sunroof glass.
you can order new glass but it is very hard to clean all the galass out without removin headliner and there may be glass stuck in track it will grind if not removed
Aug 15, 2009 | 1999 Volvo S80
Broken outside screen on razr V3i
hi guide to place front broken glass v3i open phone at the top you will 2 rubber covers remove them with a pin (pick them out) then at the bottom it will be the same but these are little round rubbers also pick the out now you should have 4 screws visible use the screw driver to remove them then once removed use the prize tool and insert it in the bottom of the v3 twist it and it should unclip remove outer panel remove glass its stuck on there very tightly but asgain prize it off then put the phone back together but dont put your glass in yet wait till its back together then remove backing tape from new glass and push it in place once your phones back together but dont push to hard lol or you will need another glass hope this helps mrjazon
Sep 03, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
139 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
