Question about Intermatic Electric Water Heater Timer #WH21
Can I use this timer, using only 120 vac to supply a 120 to 12 vac transformer?
  • 56 Answers
No this timer is rated for 240 volts so therfore the clock motor is 240 volts. You will need to purchase a 120 volt clock Good luck!
Posted on Oct 02, 2010
H ow to replace timer with phot0 cell
Malibu ML300 has 120 volt input and 12 volt AC output
They make a photo eye for the timer... wiring is changed a bit... will work on ML300 if timer has A-B-C wiring terminals
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire
You can use a 120 -> 12 volt ac transformer that is rated for 300 watts... and connect in-line photoeye on the 120 volt side.
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
http://waterheatertimer.org/Reverse-photo-eye-so-it-turns-on-at-daytime.html
Gene
Water Heater Timers Save Money
Jul 17, 2015 | Malibu ML300RTW - Low Voltage Power Pack...
I need to replace the transformer inside my 12 volt charger. I can not find who makes the ES -66-287rev5 transformer. Need help.
If you have the skill to determine the transformer input is open, I would expect you have the skill to replace a transformer. Based on this assumption: determine the input voltage (120 vac?), determine the output voltage (14 vac?), determine the power requirements (output voltage times the charging current), find a transformer at www.digikey.com or www.mouser.com or www.newark.com.
Sep 15, 2014 | Drills
How do i build a 12vac 2a adapter step by step.
Just get a transformer with a 12 volt 25 VoltAmp rating on the secondary and a primary suitable to your mains power in your part of the world. 120 VAC 60Hz for continental North America. for example.
Put a power cord on the primary with a suitable switch to shut it off, and the output of the transformer will provide you with the 12 Volts AC at 2 Amps output. Attatch the suitable adapter to the end of the secondary wires, and you are all set. AC does not have a polarity like DC.
Dec 22, 2011 | Computers & Internet
I have a customer that recently replaced his generator, problem is , he got a 120 VAC output. He has 2 SW 4024 for 240 VAC output. Can I hookup the 120VAC to the master inverter, or should I get a...
I will accept the second option which is getting transformer.
Go ahead and get a transformer in order to step up the voltage. This is better than hooking up the 120V AC to the master inverter.
In summary, get a transformer to step up the voltage.
I hope this is clear now....
Good luck.
Apr 01, 2011 | Xantrex Technology Xantrex SW Series...
I have some outdoor landscape lights that were working fine until a few days ago. The 120 vac power goes into the first transformer, and then out, and into a second, then a third, then a fourth, and...
Hi, to isolate the faulty transformer, one need to obtain a Multimeter and set it to Volts AC, then going to the Output of each transformer & see if there is the required 12V there. The one that's NOT providing an output is the faulty one.
In these setups you are correct there is little else it can be. However check at the connections to the lights also, see if there is Voltage there too.
A transformer will have the 120 V AC on the Primary, INPUT side, and 12 V AC on the Secondary OUTPUT side.
Try testing right on the transformers terminals. Also remove the "Load" too when making measurements as if there is a short etc, then that may give a false reading. Always measure Voltages first with NO load, then test again with the Load, they should both be the same, if NOT then you have a fault NOT in the transformer but elsewhere in the circuit.
Sep 26, 2010 | Garden
Where you connect the electrical cord from a fount into the timer
The Malibu ML200RT is intended to operate _12_ volt AC (low voltage) lighting _only_.
Assuming your fountain pump is 120 volts, the needed set up would be to supply 120 volt circuit to an Intermatic T101 timer (or similar timer), then connect a GFCI receptacle to the load side of the timer. You could then plug your fountain pump into the now timer controlled GFCI receptacle.
You can use the same 120 volt circuit that supplies the ML200RT transformer.
Mar 27, 2010 | Malibu ML200RT - Low Voltage Power Pack...
What power supply to use
The black& deck doesn't go with either one,
The Sb5120 uses a standard cord(no transformer)
The LinkSyS uses the LEI 12V power supply.
May 10, 2009 | Computers & Internet
Tv/dvd will not play when use ac plug
The 120 VAC to 12 VDC transformers they supplied with the TV are VERY prone to failure
Nov 25, 2007 | GPX TV6000 9 in. TV/DVD Combo
How do I replace a damaged power supply transformer on a DN-600F ?
Hello there. i'll suggest you one quick solution but it maybe dangerous!(Do it the greek way :P) try to remove the transformer from the machine. Take one Ohm meter and measure the resistance of the 120 vac coil. IF THERE IS NOT ANY (i mean that the ohm meter shows nothing diferent than not using it) get a paper blade and start removing the paper cover that it has rounded from the place where the 120 vac wires goes. you will see there that there is a mini thermal fuse.short circuit the thermal fuse and try to measure again the resistance of the 120 vac coil. if you see something between 40 and 80 ohms you are ok. Now that you haven't got any thermal fuse on your transformer just increase your security putting on a 300 mA fuse at the 120vac coil. I have done it with many hard to find transformers and it worked for me.Just be sure that when you plug it on, you will not touch it because i don't know if you are gonna do it right.ok? (say ok!) That was the second solution to your problem. The first and the safest is to go to your local dealer and order a new transformer.
Oct 12, 2006 | Denon DN-600F CD Player
Intermatic Electric Water Heater Timer #WH21 Logo
98 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
