Question about KitchenAid KGRA806PSS Gas Kitchen Range
What d oes the thermostat look like. I opened the back to see if i can find a circuit braker or something.
Go on www.whirlpoolparts.ca/POL/repair and do a search for your model. You will have access at the drawing with the part number.
Posted on Oct 17, 2010
FURNACE WILL NOT CUT OFF WITH THERMO PULL BRAKER THEN REINSERT BRAKER FURNICE WILL STAY OFF UNTIL THE THERMO IS RESET SAME THING HAPPENS AGAIN .WHAT PART IS BAD
If you have a programmable thermostat do the batteries need replacing? Test and re-insert. While there check for any loose wires on it, or at the furnace circuit board. Also make sure none of the wires are touching and metal parts and getting chaffed or shorted. If they are the shot will keep the unit from shutting off and/or cause short cycling.
Mar 01, 2015 | Intertherm 56000 Btu Gas Furnace
How do i fix my proseries water pump
unplugging it while it was runnong shouldn't damage it, probably just the circuit braker. check to see if there is a button or some type of circuit braker on the unit and reset it, if it does not have one check the circuit braker that supplies it power. (in your braker box)
Jun 23, 2014 | Pool & Spa
Cant find curcuit braker on my 97 saturn
It should be connected in series with a circuit. Since a circuit breaker acts as an "over current" switch it will be connected just an on/off would so as to "open" the circuit during an over current condition. This will remove power from the circuit.
Jul 15, 2012 | 1997 Saturn SL
No power to heater. Circuit breakers all good, reset button not activating.
YOU MUST TAKE OUT YOUR HEATING ELEMENTS AND TEST THEM.. THEY COULD BE BAD.
TESTING FOR POWER IS ALSO SIMPLE WITH A VOLTAGE METER. FIRST TEST THE POWER FROM THE OUTLET,TEST THE POWER FROM THE BRAKER , FINALLY TO YOUR HEATING ELEMENT .. AND IF IT HAS POWER JUST REPLACE IT. THE THERMOSTAT CONTROL SHOULD OPEN ONCE YOUR TURN IT ON.. IF IT DOES NOT OPEN POWER ..REPLACE THE THERMOSTAT AND PROBLEM SOLVED.
Jan 12, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The red 20amp braker at the bottom of my box keep berking with only a small amont of things pluged in. Any part of the house THE SAME BRAKER brakes . is that right? The same braker?
sounds to me that the breaker is getting weak,try replacing breaker with new one,if it still trips then you have electrical problem in a circuit.
Dec 20, 2010 | Sylvania Circuit Breaker - Zinsco/ RC 20...
Central air conditioner does not come on.
You need to check to see if you have 230 volts to the L1 and L2 side of the contactor and 24 volts to the contactor coil. If you do then the contactor coil is open and needs replaced. If not you need to check the disconnect outside by the outdoor unit and the transformer or thermostat.
Jul 03, 2010 | Heating & Cooling
Trips GFI circuit brakers
First of all, lets clarify what is going on. You say it trips the GFI breaker, so I'm assuming that it is not a GFCI receptacle that you are plugging into. So you are going to the electrical panel and resetting the GFCI breaker.  If it were a GFCI receptacle, have you tried other loads in this receptacle for 30-40 seconds, ie: Toaster, hairdryer, coffee pot? If everything works fine then there is something wrong with the ESP8XL. It would seem that there is a leakage path to ground from one of the conductors. If it is new, bring it back.
Jul 30, 2009 | Breville ESP8XL Espresso Machine
No power on kenmore range
Make sure there's power getting to your range, oven or cook top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If everything above is ok, move on to the power cord junction point. make sure the power cord has not separated from the junction point on the backside of the unit.
Jul 16, 2009 | Kitchen Ranges
LG Trom wm2077gw OE error code and won't come off and empty macine I washed a comforter and it shredded part of it and is stuck on OE what does this mean and how do I fix it. Thanks
OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
Sgt 48
May 20, 2008 | LG WD-14124RD Front Load Washer / Dryer
I have a Honeywell Programmable Thermostat T8600 and nothing displays. It was working fine, and the A/C was on on Saturday. I checked the display on Sunday and the thermostat was blank. All other lights...
check your transformer for power, should get 24V reading, if transformer is out make sure there are no short otherwise your new one will have the same fate.before checking the transformer however, make sure that your dedicated breaker for the air handler and your switch in the attic is turned on.
Apr 15, 2008 | Honeywell Heating & Cooling
KitchenAid KGRA806PSS Gas Kitchen Range Logo
57 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
