Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Seems to be leaking from the bottom. What could it be?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Most likely the pump...about the only thing that ever leaks on these machines! Part number 3363394, available from www.appliancezone.com for $25.49 + shipping
Posted on Sep 11, 2010
Water Leaks out of bottom of door
the first thing i would try is to loosen the hing screws couple of turns,push in on the bottom hinge and tighten screws.
Dec 10, 2013 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
Water is leaking from the bottom of door. Seems to pulse when leaking. Leak is bad and not just a drip or two. All rubber seems to be good.
The bottom of the door is not sealed. Be certain of the correct type and quantity of soap. Be sure the unit is Leveled.
Dec 13, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Coffee leaks out the bottom of the machine once coffee is ground and mixes with the water it seems that it is plugged and the fresh brewed coffee leaks to the bottom of the machine
The black tube that is protruding from the coffee machine is broken or leaking.If you pull out the brewunit,, you may find the broken piece stuck inside of brewunit.
Nov 14, 2009 | Saeco Odea Go
Model RAS57133PQO leaks water from bottom of
Never BUT never never ever use a washing machine that leaks. You are inviting disaster. High Voltage + Water = Electrocution.
Thought you knew that?
Get it checked by a Techo. Is your life and that of your loved ones worth the cost of a Service Call?
Oct 25, 2009 | Washing Machines
Whirlpool washer leaks from bottom when filling
So you are saying it leaks from the front ?? It would seem that the door gasket has a hole in it or the outlet hose has split. Take a torch and look at the bottom folds of the door gasket to see if there is a split in it. Switch off the power first!!!!then If not there bring the machine forward, tip it back against the wall (Put something underneath it in case it falls on you ) and use you torch to see where the water is coming from
Jun 07, 2009 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
565 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
