Question about Cyberflix Dust: A Tale of the Wired West for Windows
Cant run Dust: A tale of the wired west on windows xp
It works perfectly under winXP but it takes A LOT OF TIME!!!!! to complete the installation.
You have to be VERY!! VERY!! PATIENT, and not stop, cancel or abort the installation until it finishes.
Posted on Feb 21, 2011
My dell 1464 cant on when i try to on off agine
Try the check disk utility..
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If your laptop boots up all the way and lets you into windows but shuts down after a while it might be running hot. Three things that cause it to run hot:
1) Dust - Dust in the vents, dust all inside the laptop, dust clogging the fans
2) A fan that is not working
3) The Thermal Paste around the CPU and Heat Sink has dried up or is too thin to keep the unit cool.
May 02, 2012 | Dell Vostro 1500 Notebook
I have a west capture 7130 and it dosenot have problem with windows xp but recently I install windows 7 and my sistem gives this error: this program SAA7130 is denid acess is denided
That would indicate the card is not compatable with Win7. You need a new card. Had you run the compabilty checker first it would have told you so.
Sep 11, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have age of pirates caraibean tales but i just cant play it on windows 7.What should i do?
You need to patch it to work with Win 7. This should do it:
http://games.softpedia.com/progDownload/Age-of-Pirates-Caribbean-Tales-15-Patch-Download-12782.html
Just remember to download with care :)
May 07, 2011 | Atari Age of Pirates: Caribbean Tales for...
When running Dust: a tale of the wired west under Vista 32-bit i can't save the game. it lets me select a place to save, but clicking save dose nothing. I'm running it as an administrator and i've tried...
I had the same problem. Originally Dust was loaded on my ancient Sony Vaio running windows 98. When I got a new Dell Inspiron running windows vista I transferred all my favorite games and files via wireless connection. When I tried to play Dust the other day I had the same trouble saving. My solution was to once again access my Vaio via the Dell using wireless and track down a previous saved game. The save files being .rtd Once these .rtd files were on my dell I could overwrite them with new saved data from the game thus fixing the problem. All you need to do is find a saved .rtd file from Dust and you can once again save your games under that file. I guess Vista cannot create .Rtd files but can use them. Hope this helps; I love this game and I hope at least one person gets to enjoy it again thanks to my post.
Feb 27, 2010 | Cyberflix Dust: A Tale of the Wired West...
Cant get west front to work with windows 2000?
I recently dug this game back out, it is really cool and wanted to play it again. It was still installed on my desktop Windows XP and worked fine but couldn't get it to run on laptop with exact same problem you described. After an hour of searching the net I found this patch which fixed it and now it runs fine. You can find it at the link below. Just select the appropriate one you need.
Good Luck,
http://www.theblitz.org/downloads/patches.php#cs
Jun 20, 2009 | TalonSoft West Front Battle Pack
Ipod nano 4th gen cant sync
HI WE REPAIR ALL OUT OF WARRANTY PDAs,BLACKBERRY ,APPLE IPODS,IPHONES, AND APPLE LAPTOPS SERVING EAST DELHI,WEST DELHI,NORTH DELHI,SOUTH DELHI,NCR,FARIDABAD,GURGAON,NOIDA PLEASE CONTACT US AT JULIAN JOHN : Preet Vihar, Vivek Vihar, Shahdara, Mayur Vihar, Patparganj and Lakshmi Nagar. Pitampura - Rohini - Punjabi Bagh. - JanakPuri - Rajouri Garden - Patel Nagar
Jan 08, 2009 | Audio Players & Recorders
Install
This solution is not for the XBOX version of the game, this is only for the PC version of the game Bard's Tale.
You can still try to make the game compatible for installing it on the Windows XP 64 bit by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
The same set of Compatibility steps can be used for installation of older games installation on Windows XP 64 bit and Windows Vista.
Again, this solution is not for the XBOX version of the game.
Sep 06, 2008 | Vivendi Universal Bards Tale: Song of the...
Cyberflix Dust: A Tale of the Wired West for Windows Logo
564 people viewed this question
Top Cyberflix Video Game Consoles & Games Experts
James Wishart
Are you a Cyberflix Video Game Console and Game Expert? Answer questions, earn points and help others
