Question about JVC AV-48WP30 48" Rear Projection Television
The tv looks like it is in 3d. when i try to adjust the convergiance the plus signs on the left are bent
  • JVC Master
  • 8,457 Answers
The tv convergence function can't fix R,G,B colors lines mis alignment,colors shadows and 3D pictures.The tv convergence board require changing 2 STK convergence ICS and some or all it resistors are dead.The shop,will cost u $300-350 for parts and labors.
Posted on Sep 11, 2010
  • 63 Answers
Do not play with this tv replace the stk ic chips and the resistors around the stk chips ,cant miss em about 2 inches big with heat sinks on them.
The convergience is off(screen is different colors) &I don,t have the remote that goes with it (broken). Where can I get the remote for the tv because a universal wouldn't work?
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 03, 2011 | JVC AV-48WP30 48" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have a model 60PP9202 60" Phillips projection TV that has color convergience problems. It started a few years ago when the TV wouldn't turn on at all. After unplugging it for several hours, it...
Below is a link I have included. This is a site I use to repair parts in projection tvs. The kit includes detailed instructions on how to repair it yourself. If this told you something you did not know rate this solution as very helpful as I do this here for free.
ALSO, if you have questions reply to this posting and I will assist you--I am here to help.
http://www.tvrepairkits.com/xcart/product.php?productid=23609&cat=3647&page=1
Jan 05, 2011 | Philips 60PP9202 60" Rear Projection...
Picture like it is in 3d when i try to adjust the convergence the plus signs on the left are bent
Set uses two of the STK-392-110 chips and board they are mounted on is easy to get out---On EBAY a pair will cost about 12 dollars. Total parts cost should be under 25 dollars. I can tell you best way to get at them and replace them.
See attached photos--this is board in your set with the chips--black in color and number right on the front of them.
If this told you something you did not know and you need further assistance, rate this solution as very helpful and comment here as I do this for free.
SD TECH
Sep 11, 2010 | JVC AV-48WP30 48" Rear Projection...
Convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 06, 2010 | Mitsubishi WS-65869 65" Rear Projection...
The picture arced and looks 3D. Plus the screen
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 10, 2010 | Mitsubishi VS-50607 50" Rear Projection...
The convergiance is way off like a 3d pic. and it will not adjust in. what can i do.
Replace your convergence ICs They will be big black ICs will have the partr number on them example....STK394-250 Go by the STK# on yours Call Mats for Parts 1-800-628-1118
Sep 24, 2009 | JVC AV-56WP30 56" Rear Projection...
I have jvc-56wp30 the color convergience is way off like a 3d picture. it will not converge.
  • Screen looks 3D
Bent picture
Not sure if you fixed your problem already. But the answer is a color convergence problem. You can try adjusting manually via the remote and if that doesn't work it is most likely the two main IC chips that control the color convergeance. It is also possible that not only the IC chips have gone bad but also there are a couple of resistors that usually burn out with the ICs as well. They will need to be replaced. This isn't something that I would attempt on your own. Typically a TV technician will charge between 300 and 400 to fix at your house.
Mar 15, 2008 | Philips 60PP9363 60" Rear Projection...
Convergience
Hey Cancun,Ill be able to Answer this on Tech Support my Screename ttech
Oct 05, 2006 | Hitachi 43UWX10B 43" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
115 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
