Question about Health & Beauty
Beeps when key is first turned on and will not move. have to turn on and off several times before it starts working right. it does this several times a day , but not every time she turns the key on?
  • j_gordon2448 Sep 11, 2010
    not sure model # will have to find later. do know it's a Pride Victory 9- 3 wheel less than a year old and just had the batteries replaced last week. i have tried moving the free wheel lever back and forth with no help.all connections still look brand new?
  • j_gordon2448 Sep 12, 2010
    Thank you ! Will contact Pride to see if still covered under warranty . Does not seem like an easy fix .
  • 17,129 Answers
Two issues, the first is that the key itself is faulty as there can be poor connections in the multiple switches as only at a particular time the total contacts lock on.
The second can be that the switched power is not activating main board to activate the control drive.
check for errrors in the connectors, links. Maybe remove and setting it back can made it work in which case a good cleaning should be done.
Posted on Sep 11, 2010
    President:
  • 1,566 Answers
Hello there,
Can you tell me the model of this unit?
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Fisher & Paykal MW512 turns on multiple beeps then turns off
    This kind of problem is usually related to a faulty display module, or faulty motor control module (Computer isnide of control panel compartment)
    Without spares to change and test with, you wont be able to diagnose 100%
    Usually when there is a problem, a series of lights go solid on the control panel and the machine beeps to alert you to a problem and this is a fault code, but if nothing is showing at all, then I have to lean towards the display module underneath the touchpad. Especially considering it wont illuminate.
    Nov 22, 2012 | Fisher and Paykel Fisher & Paykel Washer
    How to turn off change oil light on the 2004 Chevy Colorado Pick-up truck ?
    1. Turn the ignition to ON do not start.Engine OFF dash board lights ON.
    2. Press and release the reset button in the driver information center (DIC) until the OIL LIFE message is displayed.
    3. Once the alternating OIL LIFE and RESET messages appear on the DIC display, press and hold the reset stem until several beeps sound. This confirms the OIL LIFE system has been reset.
    4. Turn the key to lock. If the CHANGE OIL message comes back on when you start the engine, the ENGINE OIL LIFE system has not reset. Repeat the procedure
    Alternate Method
    1. Turn the ignition key to ON with the engine off.
    2. Fully press and release the accelerator pedal 3 times within 5 seconds. Several beeps sound. This confirms the oil life system has been reset.
    3. Turn the ignition key OFF.
    4. If the CHANGE/OIL message comes back on when you start the engine, the engine oil life system has not reset. Repeat the procedure
    I use the second method, it is more universal and it works for Chevy Venture too.
    Nov 06, 2010 | 2003 GMC Sierra
    Beeping sound when starter is turning over for the
    Have u replaced the spark plugs? Is this the beeping noise you hear when you first turn your key over the same as past times you have started the motor? It just keeps going though right? I would make sure you have the right level of fluids and make sure your fuel pump works, fuel filter isn't clogged and plugs and wires are in good shape.
    If that is all good then you might have a bad coil pack. Test it and make sure you are getting correct voltages, if not then replace it.
    Also did you winterize your motor after the last time you used it? If not you could of cause some internal damage to the motor.
    Good Luck,
    Subikid90
    Mar 04, 2010 | Boating
    After flat tire, tire pressure warning will not go out even after making sure pressure is at 44psi. How do I reset dash?
    44PSI?? is that what your car recommends...
    1. check and make sure that your tires are inflated to the correct pressure
    2. turn the ignition switch to the ON position. If the low tire pressure warning light comes on, push and hold the tire pressure warning reset switch (think the switch is in the glovebox, but not sure) until the warning light turns off and then release the switch.
    3. now press and hold the tire pressure warning reset switch until the low tire pressure warning light blinks three times.
    Aug 14, 2009 | 2006 Hummer H3
    Key does not turn on ignition. Won't turn at all. Cannot start the car or have it towed since it is stuck in park.
    Have new key cut,stop at hardware store and get liquid wrench spray ,spray lube in cylider,then put key in and out several times briskly before trying to turn.If this does not work open hood and pop shift cable of trans selector lever and reach down and move lever to neutral position two notches.then can tow.
    Jun 19, 2009 | 2001 Chevrolet Cobalt
    Ignition won't turn to start the car
    the lock cylinder may have to be replaced, have you tried moving the steering from side to side while trying to turn the key, if you do need to get a new ignition lock cylinder have a lock smith key it to fit your old keys
    Jul 30, 2008 | 1991 Oldsmobile Cutlass Ciera
    Wheelwriter 1000 (IBM) beeping
    You may have the R. margin there. Space all the way to the right, press R MAR key. You also could have spellcheck on code 1 will turn it off
    Jan 28, 2008 | Lexmark Wheelwriter 1000 Typewriter
    Beeping
    It most likely beeping because it cannot make its resetting movement. That is,it cannot "find-out" where its left margin is. There may be something hindering the actual movement of the print carrier. Check inside the typewriter by lifting up the top cover and move the print unit by hand. It should be able to move from the left to right-hand side of the typewriter unhindered. The shaft that the print unit moves on should be clean and it may have gathered dust etc,so give it a wipe with a clean cloth (lint free) with a small drop of light oil on it.. Replace the top cover and switch on the machine
    Nov 05, 2007 | Nakajima AE-740 Typewriter
    Health & Beauty Logo
    56 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
