Question about Nespresso Le Cube
Hi, My Nespresso LeCube doesnt make full espresso or coffee anymore. It only fills the espresso cup less than 1/3 and its very diluted. Appears the rest of espresso falls into the drainage area. I have checked and restarted, and tried many times but the problem still persists. Capsules are also punched appropriately. Any idea?
I had the same problem. First, unplug machine for two (2) minutes. Then re-plug and as on/off switch is flashing- press and hold large cup button for 3-5 seconds (no light should show/flash from this button while you hold it down. The on/off will continue to cycle through its normal startup, after it completes you should be reset to factory settings and good to go. Good luck to you, this maneuver saved me.
Posted on Sep 13, 2010
  • KidLid Jan 03, 2012
    Hi, I have the exact same problem with my Nespresso Le Cube. I have tried your suggestion with no luck. I've also descaling. Any further suggestions?
Nespresso pixie c60 only brews for a few seconds on full cup mode
Would love more info, like how long did you have this item and did it go from 10 seconds to 3 seconds with less water over a period of time or just over night?
if this has been giving you less and less water and taking / shorting the amount of time you might have Calcium build up inside the unit that is not that easy to clean out, Seen it happen on a mr coffee unit it would make a 1/2 pot of coffee because of the build up from the hard water in the area.. Needed a new coffee maker.
Dec 09, 2014 | Nespresso Pixie C60 Espresso Maker...
I have a nespresso D290 It shows that its on but a small yellow light keeps flashing and when I push other buttons it beeps
The instructions for your Nespresso LeCube 250 can be downloaded here:
http://www.nespresso.com/fileadmin/ca-en/_img/manuals/NES_08_00_EN_Nespresso.pdf
The flashing light may indicate a problem with the heating system and proper water temperature is not being reached. Have you descaled your machine?
You may wish to seek guidance from Nespresso: 1-800-562-1465
Oct 30, 2011 | Nespresso D290 Espresso Machine
I have the keurig b40 machine and it does not brew a full cup of coffee anymore, it only does 1/4 a cup of coffee
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 08, 2011 | Keurig Elite B40 Coffee Maker
When i put water in the water tank it will leak after i make my cup of coffee and it doesnt fill the cup full. what is the problem
heatman101
Aug 04, 2011 | Keurig Elite B40 Coffee Maker
Does not produce full cup of coffee, only fills cup about 1/4 when full setting selected
heatman101
Jul 10, 2011 | Keurig B60 Coffee Maker
When you press the button for a large cup of espresso (Nespresso Essenza) only small amount comes out
You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. The small cup that you are currently getting was probably set at the factory. Good luck
Nov 19, 2009 | Nespresso Essenza C100 Espresso...
Water leakage inside
Use less water....
Apr 29, 2009 | Krups Nespresso 554
Too little coffee
reset to factory default...
1. Power switch off
2. Press & hold coffee cup button while powering back ON
Mar 22, 2008 | Nespresso Essenza C100 Espresso...
Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Aug 20, 2007 | Nespresso C190 Espresso Machine
Nespresso Le Cube Logo
3,039 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
