Question about Pride Jazzy Select 6 Indoor Power Wheelchair
Jazzy select hasnt been charged over a long period and now batteries are not charging manuel says they may not charge to call provider what will be done can they be charged again?
  • Anonymous Mar 21, 2014
    battery won't charge
  • 692 Answers
Virginia sorry no. Your charger cannot pickup low batteries and charge them. You will have to purchase 2 new U1 batteries. If Medicare purchased your chair then they will pay for most of the cost of new batteries. If you bought the chair then I would look for a battery warehouse type store or an Interstate battery store and buy them there they would be somewhat cheaper than buying them from a provider. Hope this helps you
Posted on Sep 11, 2010
I am new at this i plug in c harger and only powre light comes on, is it charging or is the chatge light supposed to come on?and how long does it need to charge a jazzy select?
If your charger has a red and a green led on it when the green led lights the battery is charged. If you use it a lot during the day it may take 8 to 10 hrs or more to fully charge the batteries
Jan 11, 2014 | Pride Jazzy Select 6 Indoor Power...
Only the red light comes on jazzy select charger
Batteries must be stored on a full charge. For extended periods they should be disconnected. If your batteries are flat/dead the charger will not attempt to charge them. You should remove your batteries and check and try to charge them individually. Sometimes they will come alive, must of the time they won't. Charge them individually with a 12 volt 2 amp charger - no higher; or in series with a 24 volt 4 amp charger.
Mar 01, 2013 | Health & Beauty
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Jun 04, 2012 | Pride Jazzy Select 6 Indoor Power...
How long does it take to charge jazzy select gt
Mike it depends on the charger and how discharged the batteries are. But if you get into the habit of charging it overnite when you get up in the morning it should be good to go. A 3 amp charger will take longer to charge than a 4 amp or 5 amp. Now if you are charging overnite and still don't get a full charge then you could have battery problems ie one weak battery causing the chair not to get fully charged or it could be the charger but if the charger has been doing ok in the recent past then I would have to suspect the batteries Hope this helps
Feb 19, 2011 | Pride Jazzy Select 6 Indoor Power...
Jazzy Select 6 Indoor Power Wheelchair: how to charge...
The Jazzy Select 6 requires an off-board charger. Plug the charger into a grounded outlet; preferably one that doesn't have other large loads on the circuit like refrigerator, freezer, microwave, etc. The male 3-prong XLR connector coming off the other end of the charger plugs into a female XLR connector which is on the joystick control's bottom-rear. Charge it overnight after each days use, and at least once each month overnight. You should get 2-4 hours of use from the chair at top speed with a 200 pound driver, depending on terrain and climate. If it isn't holding a charge, you will probably need two new U-1 type gel sealed batteries that run about $120.00 or so each. Make sure you test the old batteries first at a knowledgeable battery shop. These are deep cycle batteries and require a special testing. If the batteries are good, then your charger isn't charging. Search EBay or other online sites for a wheelchair charger in the 4-6 amp range. They can be found for about $45.00 or so. Pride will charge you a lot more.
May 18, 2010 | Pride Jazzy Select 6 Indoor Power...
Jazzy select 14 won't charged - have replaced batteries
At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity it says it fully charged but will die quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential resulting in short battery life. Also the new batteries need to be charged before they are put on your jazzy. Then its a matter of if not in use put on charge. I think you need to have a word with your dealer.
Oct 06, 2009 | Pride Mobility Products Jazzy Select 14
Pride Jazzy Select batteries not charging
If you use an automotive charger you have to charge each battery individually as they should be 12vdc hooked in series.
Clean contacts and assure yourself that each lead is charging properly. Jazzy has many different models so it impossible to know which you have. But there should be some info on the charger to tell you if your output is 24v or 2-12volt DC leads.
Jazzy has a web site and there is a member section where you can ask questions.
May 16, 2009 | Pride Mobility Products Jazzy Select
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
466 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
