Question about Kenmore 24 in. 15933 Built-in Dishwasher
My Kenmore Elite works fine but I am finding a strange orange film collecting on the racks, and creeping onto everything. I clean it and it comes back. Occassionally the dishes end up with a white film here and there. How do I solve this??
  • 22 Answers
Do you have a water softener? if so it may need servicing. If your in a rural area and have your own well, you may have what is called red water iron, depending on the amount your softener should take care of this if working properly.
Posted on Sep 11, 2010
Kenmore Elite dishwasher won't clean and leaves white film
CHANCES ARE YOUR WATER TEMP IS TOO COOL and the 2nd
PROBLEM IS VERY HARD WATER THAT IS CAUSING THE WHITE RESIDUE. RAISE THE TEMP ON HOUSEHOLD WATER TO 140 F AND ADD SOME SALT TO THE WASH CYCLE. LASTLY USE A LIQUID DETERGENT LIKE LIQUID CASCADE.
Oct 13, 2012 | Kenmore Dishwashers
Kenmore elite model 665 17263402 The top rack is not cleaning the dishes. The bottom rack is cleaning fine. What is causing this and how can I fix it? Please help.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
How do I get rid of the stinky smell of my front loader?
The smell comes from your front rubber boot you must replace it toget rid of the smell.The water collects in the inner part of the boot and and sits there till it smells hope i helped
Sep 20, 2009 | Kenmore Elite 45986 Front Load Washer
The upper sprayarm flows water but does not turn. Therefore dishes in upper rack are not geting cleaned.
i have a kenmore elite dishwasher model 665.16059400, i need a lower spray arm nut, nobody can find this part, i've been to sears and also to their on line parts department 3 times and have come up empty, the last time i was assured that the nut would be included with a new spray arm if i ordered one, it was not,i know the spray arm was made by whirlpool, is there anyone out there who knows the solution to this simple problem? does whirlpool have a cross referance model number i can use to find this part
Apr 29, 2009 | Dishwashers
The top rack on my kenmore dishwasher is not cleaning the dishes!
check the inlet strainer at the bottom of the unit - and also the nozzles on the top are for clogs/sediment.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Kenmore Elite 45986 Front Load Washer
Airgap spills over onto sink every time we run the dishwashers
Hi Jose31,
I'm Harvey the Master Plumber.
Your question is: Kenmore Elite dishwasher.airgap spills over onto sink every time we run the dishwashers. what to do?
This is very common! In most states the airgap is no longer required for this very reason. It's one of those ideas that looked good on paper. In my state I remove it. If you have to keep it, thats OK. All is not lost. The real culprit is crud buildup in the airgap discharge tube. You would have to remove it and clean it and the fittings. And next year do it again. May not be as simple as it sounds. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Aug 07, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite
This is a guess but worth trying:
First, check to see if there is any food material in the drain area. There is a screen which may be restricted. This will restrict water flow. Second, if that doesn't work, there is a solenoid which directs water from the pump to either the drain or to the wash nozzles. It is probably stuck part way. It may be cleaned. I once found a toothpick in one!
Sep 01, 2007 | Kenmore 15129 Built-in Dishwasher
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 24 in. 15933 Built-in Dishwasher Logo
76 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
