Question about Garmin Rino 110 (14 Channels) 2-Way Radio
My Garmin Rino 110 turns on the radio works but the screen is blank. Any ideas?? NEED help ASAP!!!!!
4 Suggested Answers
SOURCE: broke rino
I had a similar problem with my account.
I pushed the one batteripolen down as it started up again.
Posted on Aug 09, 2008
Driver_851
  • 13 Answers
SOURCE: RINO 120 :: screen blanks out with just a single horizontal line
Had to wait 24 hours to be able to post my own answer
By reading a number of forums, I've found that there was a WAAS satelitte update (bug), that causes this foul up.
The only solution I've been able to arrive at is DISABLE the WAAS feature, as no Garmin Update/patch (for Rino120) has been made available.
To shutoff the WAAS feature press your [Page] button until you arrive at the "Main Menu"
go down until your on the "Setup"(hammer)
go in (by pressing in, on the directional button)
go down until your on the "System"(gears)
go down until your on WAAS, go in and select the Disabled
go up to the "X" (top right) press it, then you can [Page] button anywhere you want from there.
Wonder what WAAS is?
http://www8.garmin.com/aboutGPS/waas.html
Take care.
PS- Garmin if you read this....I would like to have my WAAS back, and since I registered for updates, back in 2005, why didn't I get an email from you telling me about this issue (when it happened and provide a solution - at the same time :: even a work around as I've posted here)
Posted on Oct 03, 2008
SOURCE: Garmin Rino 130 Shut Down
I was having the same problem, but thanks to SnappyWD's tip I'm am back up and running again. I use my RINO 130 almost exclusively while riding and racing a motorcycle in the Southern California desert, so it has/does take quite a of bit being bumped and tossed around. I took the unit apart as Snappy said, but instead of bending the pin back, which is the connector from the batteries to the circuit board, I re-soldered both battery connections to the circuit board. While they looked OK to the naked eye at first, they clearly were the broken link. I have bashed the unit pretty hard now and it works as good as new! Thanks SnappyWD!!
Posted on Apr 16, 2009
It turns on i can barely see the screen; does it have a dimmer switch? and if so;how can I fix It if i cant see the sceen? thanks ssg figueroa
to brighten up the display, after unit is on press the power button again and you should get the light and contrast contols. works on all of mine.
Bob
Jan 14, 2011 | Garmin Rino 110 (14 Channels) 2-Way Radio
Rino 110 will not aquire satilite signals.
To have a signal you have to go out in an apartment may not work
Apr 03, 2010 | Garmin Rino 110 (14 Channels) 2-Way Radio
Garmin Rino 530 radio noise even with squelch turned up. Hissing
Are you carrying a cell phone with you at the time? A cell phone can interfere with these units. You may want to call Garmin to ask questions on this problem. They are very helpful and professional.
Dec 30, 2009 | Garmin Rino 530 GPS Receiver
Back cover where that contains the batteries broke
Contact garmin at garmin.com, this is not an accessory, that you can buy anywhere, so send them an e-mail and see what they say.
Mar 31, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Garmin Rino 110 Posted by nightjar on Jun 29, 2008 My two 110's have same problem. With two new sets of different brand NiMh rechargeables the problem still exists. Both units get warm and flatten the...
Re : " Both units Garmin Rino 110, overheat and flatten the batteries within 2 hours"
That is a factory defect related to a bad contact inside the unit.
If you contact garmin and insist to talk to a supervisor (second line) you can have both Rinos replaced.
Ensure it is not a bad batteries problem first testing a replacement battery, both batteries may have deteriorated at same time.
Buy first a replacement battery at Garmin eTrek, Rino 110/120 NiMH Battery,
If that does not solve the problem call Garmin:
See: Garmin | Contact Us
Feb 09, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Screen goes blank except a thin line
There is a firmware upgrade from Garmin that appears to address this problem for units still running Version 3.2 or earlier. If your problem only occurs when WAAS is enabled, you might try upgrading. To find what firmware version you have, from the main menu: Setup, System, then select the (options) icon on the top row, to the left of the 'X'.
Nov 24, 2008 | Garmin Rino 120 2-Way Radio
LED does not work
you have damaged the screen and it will likely need replacement. there is one other possibility... you may have loosened a connector inside the radio... tap it gently with your finger to see if there are any changes in the display
Robert
Sep 20, 2008 | Garmin Rino 120 2-Way Radio
Turn it on - black screen
Dropped the rino 120 and the led is blank but radio works
Sep 01, 2008 | Garmin Rino 120 2-Way Radio
Rino 110 stuck in one mode
There was a change to the WAAS satelite protocols. There is a new software download to fix the problem. The link is: http://www8.garmin.com/software/WebUpdater_241.exe
Jun 09, 2008 | Garmin Rino 110 (14 Channels) 2-Way Radio
Broke rino
Mar 12, 2008 | Garmin Rino 120 2-Way Radio
Garmin Rino 110 (14 Channels) 2-Way Radio Logo
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Computer Repairing
Computer Repairing
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
