Question about Samsung Touch of Color UN46B6000 46 in. HDTV LCD TV
I conducted the cound test and it told me to contact the call center. The model # is un46b6000 Soft version t-che6ausc 1012.0 serial # az1h3cks908107b version sq01 thanks, amyblasczyk@bellsouth.net
What is the idm serial code
all serial codes should be printed on a sticker, on the underside of your computer.
Feb 09, 2013 | Dell Inspiron Mini 1012 Netbook...
Sim card missing
Use a different SIM card and reboot, If gives the same error kindly contact Nokia Care.
Aug 28, 2012 | Nokia 100 RH-130 CV UK FESTIVAL PINK
Where to purchase Dell Inspiron Mini Black 1012 key pad for replacement in Kolkata, West Bengal
you must purchase it from authorized service center because this key pad is available in company. ss contact nearest customer support.
Sep 16, 2011 | Dell Inspiron Mini 1012 Netbook...
My dell mini 1012 won't boot up, just beeps 8 times over and over again.
Trying unplugging the computer, remove the battery, open the memory door and remove the memory, clean the memory contacts with a clean dry soft cloth and then replace. Replace the battery, plug in the computer and try again. Sometimes residual power builds up ...
Aug 08, 2011 | Dell Inspiron Mini 1012 Netbook...
Screen stuck on "Serial (Top)-HP blue logo Invent (Center)-v1.08"
have you tried starting the ROM update over. if it recognizes part of the update it may give you an out back to your previous version. good luck.
Jan 19, 2010 | HP iPAQ H2200 Pocket PC
Where is the serial number on an HP Officejet J6480 All-in-One printer
Usually the serial number can be found either in the back or in the bottom of the printer.
If your printer is working you can print a self diagnostic page which would have the serial number.
To print the Self-Test Diagnostic Page
• Device control panel: Press Setup, select Print Report, select Self-Test Report,
and then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print a Test Page.
Sep 09, 2009 | Office Equipment & Supplies
Can not print printer only prints test page
you have the wrong print driver installed (either wrong model or wrong OS) also check if there is a PCL or PS print driver and printer port is correct (USB, tcp/ip, Serial)
Aug 04, 2009 | HP LaserJet 1012 Printer
Authorization code plsss
Suhaimi, only Adobe has the ability, much less the authority, to give you that code.
I also hate to tell you this, but you might want to try purchasing another copy of Photoshop, or speaking directly to Adobe, if that is a legitimate copy you are having difficulty with . While I like to consider myself an honest and fair person and will never cheat someone- there are people that have no doubt come across this post and are using that serial number and activation code to activate their own illegal versions now.
It is for this reason you should NEVER show your product serial number or activation code to ANYONE unless you know them and trust them well enough not to pirate your software. the serial number is your "proof of purchase".
here is their customer contact area, if you still need help with contacting them for further support.
http://www.adobe.com/support/service/
good luck!
- Demolitio
Aug 02, 2009 | Adobe Computers & Internet
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
Samsung Touch of Color UN46B6000 46 in. HDTV LCD TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
