Question about Kids II Bright Starts Booster Seat
I want to have a copy of users manual instructions of Bright starts By your side infants seat for the assembly and features of the said product. Thank You
Replacing washed cover of I toddler car seat
Hi
Instructions on removal of carseat fabric can be found in your User Manual. If you no longer have the User Manual visit www.maxi-cosi.com and select the country you're in, then choose the carseat you have and click the Service tab to download a replacement copy.
Sep 14, 2013 | Maxi-Cosi Cabrio Red Flame Reflection...
How do i take the covers off to be washed
Full instructions are in the user manual. If you no longer have your user manual you can download a copy from www.maxi-cosi.com
Dec 21, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How do u get the fabric cover off the baby car seat to wash it?
Good Afternoon
Full instructions are in the user manual. For a copy of the user manual if yours has been lost go to www.maxi-cosi.com and select the carseat, then select "Service" and you can download a copy.
Alternatively go to our Facebook page Dorel UK Customer Services and full picture directions are in our photo album.
Aug 31, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I washed my daughters graco car seat and now i havent a clue of how to put it back together and i need re assemble it fast please help
Proper installation of a car seat is imperative to protectan infant. Accidents do happen and assuring that the instructions forinstallation of the Graco Infant Restraint/Carrier are followed will increasethe chances of preventing injury or death as a result of an accident. Graco carseats are a popular choice among parents due the availability of products atcommon retail stores, affordability and user-friendly baby gear.Graco Car SeatInstallation
Step 1
Plan to secure the infant seat facing the rear inthe middle of the back seat. If a center position is not available, positionthe seat directly behind the driver's side seat. For safety reasons, therestraint should not be placed in a position where there is an air bag. Ensurethat the proper vehicle lap belt system is in place; manually adjusted lapbelts, automatic locking retractor lap belts and lap/shoulder belts withlocking latch plates are all considered safe for use with the Graco InfantCarrier/Restraint.Step 2
Remove the carrier from the Graco car seat baseby squeezing the lever at the rear of the restraint and lifting the seat up.Place the base in the vehicle facing the rear. Thread the vehicle shoulder andlap belts through openings at the end of the base without twisting the belts.Secure the belts by placing plastic tongue over the belts. Tighten the vehiclebelts by pushing down on the base and pulling out any slack.Step 3Install locking clip to secure shoulder and lapbelt together just above the seat belt buckle. Connect the two belts with thelocking clip. Buckle the lap belt system and tighten by pulling out any slack.Ensure that car seat base is secure by pulling and pushing on it; the baseshould not move sideways, forward or backward.Step 4
Place the Graco carrier in the base. Push down onthe restraint until it clicks and locks into the base. Set the infant in therestraint for travel and place harness straps over the baby's shoulders. Clickthe chest place together over the sternum and lock the buckles into placebetween the legs.Tipsand Warnings
  • Contact local police departments, hospitals and fire departments to inquire about child car seat safety checks
  • Graco Infant Restraint/Carrier will not protect against serious injury or death if not installed properly. Always read the Graco owner's manual that comes with product prior to attempting installation and travel with an infant.
Jul 19, 2011 | Home
How do you install the car seat in the rear facing position?
Full instructions on correct installation are in the user manual. To download a user manual please visit www.maxi-cosi.com and select the seat you wish to download the manual for.
Jun 21, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Good afternoon, I have taken the sun hood off the car seat and I am not sure now how to get it back on, please could you tell me to do this, it is a maxi cosi cabrio fit car set. Many thanks Janie...
Good Evening
Instructions for fitting the sun canopy can be found in your user manual.
If you no longer have your original copy of the user manual please go to www.maxi-cosi.com and select your country. Now select the CabrioFix carseat from the list of available carseats and download a replacement user manual.
May 09, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I need to clean fabric does it come away from seat
Good Evening
The fabric on all Maxi Cosi carseats can be removed for cleaning purposes.
Instructions for removing the fabric can be found in your user manual. If you no longer have your user manual you can download another copy at www.maxi-cosi.com Select the CabrioFix carseat as your model and you will see a tab over the image to download a copy of the manual it has a step by step guide in here for how to remove the fabrics to clean them.
It is recommended that fabrics are sponge washed by hand and dried naturally. Use a mild detergent suitable for hand washing and ensure it is thoroughly rinsed. To prevent discolouration of the fabric do not leave it to dry in direct sunlight. The fabric should not be tumble dried as this may cause unsightly bobbling.
Jan 16, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Once removed how do you replace the cover and put the strap back correctly for rear facing maxi-cosi car seat?
Good Evening
Instructions for replacing your fabrics are in your Maxi Cosi CabrioFix user manual. If you no longer have your user manual you can download another copy at www.maxi-cosi.com and selecting the CabrioFix carseat. Above the product image you will see a tab to download a user manual.
If you have removed the harness from the carseat completely this carseat needs to be sent to our engineers for them to re-thread the harness. Due to the safety implications of this being done incorrectly we cannot recommend that this is done by anyone else. The standard charge is £50 and this would include courier delivery service of the carseat back to your address. In addition you will need to make arrangements and cover costs for a courier delivery service of the carseat into our engineers.
Jan 08, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I need the exact instructions to graco infant carseat
Look on the back or bottom of the seat to find the model number and then you can download a copy of the owner's manual here.
Dec 24, 2008 | Graco Snugride - Family Tree Infant Car...
Kids II Bright Starts Booster Seat Logo
105 people viewed this question
Top Kids II Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Kids II Baby Gear Expert? Answer questions, earn points and help others
