Question about Craftsman 12amp Electric Blower with Vac Kit
I can't find the switch to change from suction to blowing leaves. Can you help?
    President:
  • 1,851 Answers
there is no switch - you must place the plastic on the unit and remove the round piece from the suction area. You need a copy of the instructions for sure. It is complicated to switch from one to the other and takes a long time. hardly worth bothering with for me
Posted on Sep 11, 2010
Just bought a power devil fairway 1600 with no manual , suction wont stay when switched to blow . any ideas
did you buy it second hand? Looks kind of screwed-up.
Sorry, no user's manual available on line.
Maybe contacting them?
http://www.cylex-uk.co.uk/reviews/viewcompanywebsite.aspx?firmaName=power-devil&companyId=13001676
Some customers' ewviews. maybe you get a tip?
Amazon co uk Customer Reviews Power Devil PDGSV1600N Garden Vac 1600W Old...
Contact Power Devil, Royton, Middleton Roadroyton.cylex-uk.co.uk
Oct 11, 2015 | Vacuums
Pressure switch stuck closed
The pressure switch is located in the burner compartment. It is round with a rubber tube going from the inducer blower motor housing to the switch itself. When the furnace has a call for heat, the inducer motor will start. At this point, it pulls the pressure switch in, caused by the suction from the housing and rubber tube. If the switch is stuck closed, you then have a code and the heater will not work. One way to check if the switch is operating correctly is to pull the rubber hose from the housing but leave it connected to the switch. Blow and **** in on the hose and see if you can hear the switch opening and closing. It should make a clicking sound. If no clicking sound, the switch is faulty and needs replaced. Also, take a small piece of electrical wire and poke around inside the opening where the hose came off of, sometimes this can get clogged and causes the switch to stick open or closed. You could also have a malfunctioning control board which is more difficult to diagnose. Hope this helps!
Jan 15, 2012 | Goodman GMS90703BXA Heater
How do i change from vacuum to blower?
In order to change from suction to blowing, insert the hose into the
exhaust port of the vacuum cleaner.
The vacuum cleaner should have two ports, one which is for suction,
the other is an exhaust port. The exhaust port can be used for blowing
when the hose is inserted into it.
After inserting the hose into the exhaust port just turn on the switch.
Jan 17, 2011 | Black & Decker UV200 Wet/Dry Vacuum
I have cleaned out the vac and changed the filter but I can hardly **** up leave on the garage floo.
Try this:
Detach hose, turn on vacuum, hold hand in front of intake to check airflow/suction. If it seems good, you either have a clog in the hose, are bad leakage.
If it's a clog, try placing end of hose in the exhaust port, turn on machine, and blow clog free. You may need to place other end into intake. This should clear it.
If hose is cracked, punctured, or smashed/collapsed, replacement will be necessary.
If there's not much suction at the intake, it may be time to replace your vacuum, or at least the motor.
Nov 13, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
The aircondition is on and blowing hot air,the fan
Have you checked your filters to make sure they are not dirty? Is the Insulated suction line starting to get
covered in ice? Is the indoore coil Iced up?
If yes, turn furnace off, try and change the filters,leave
unit off for awhile while it unthaws and try it a few hours later.
Jun 24, 2010 | Heating & Cooling
Our Dirt Devil D2 bottom has no suction
I would check the bottom of the unit to see if there is any blockage. I don't know if this unit has a switch that you set to switch from hose to floor. If so I would set it to floor and see if there is any suction in the hose, indicating a switching problem. If there is no suction in the hose, I would still check the bottom of the unit and disassemble it as much as you feel comfortable to see if you can see any blockage. Good luck!
Mar 13, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
My steam vac is not cleaning the only place their is suction is through the uphostery hose, can't find my book or a switch to change from upholstery to the fllor suction. Any ideas?
You need to remove the suction hose from the front nozzle in order. There is no switch to change suction control. when the hose is removed, make sure the dorr cover is closed.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 21, 2009 | Hoover F7431-900 SteamVac Vacuum
Suction stopped working immediately
There is a hose on the unit. Disconnect it at both ends. Stretch it out. Look down it. If you can't see down it, rod it out.
May 28, 2009 | GE Vacuums
Vacuum won't **** in upright position, but there is suction from the hose in the upright position
theres a knob that switches it from floors to carpet turn the to floors.please leave feedback
May 03, 2009 | Vacuums
Ac fuse blowing, high suction pressure
Were the fuses blowing before you started charging the unit?
It sounds like you are overcharging it.
Apr 26, 2009 | Heating & Cooling
Craftsman 12amp Electric Blower with Vac Kit Logo
149 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
