Question about Panasonic NN-T793SF Microwave Oven
How do I get my panasonic genius prestige out of demo mode?
  • 4 Answers
SOURCE: My Panasonic Genius is in
Push clock button 3 times. This sets the demo mode and undoes it too.
Posted on Nov 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Panasonic Genius Prestige Model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can order Panasonic parts here.
You can find an authorized Panasonic servicer here.
Posted on Sep 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Stuck in Demo mode
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If that doesn't work, check the owner's manual.
You should be able to download your Panasonic owner's manual here.
Posted on Dec 07, 2008
falter
  • 245 Answers
SOURCE: we had a power blackout now my panasonic genius
hi sorry to hear whats happened.....but very simple solution.....
turn power switch off for a few sec and then turn on again....this will reset ur microsoft to factory setting like it was when u got it from the store....just follow manual instruction if needed.....this will solve ur problem for sure
good luck and happy cocking
Posted on Mar 07, 2009
SOURCE: how to unlock child lockout. Genius
press stop 3 times
Posted on Dec 24, 2010
My Panasonic genius 1250w shows DEMO on screen and does not respond to settings
"DEMO MODE" is a tool intended for in-store demonstration of the microwave oven to the consumer.
While in Demo Mode, if you push "START", the microwave will not fully operate as designed. To Exit Demo Mode, press the "Timer/Clock" button four times. If it does not work, see to your operating manual.
Nov 05, 2017 | Panasonic Microwave Ovens
Why does it stay on demo mode?
Once a unit is in demo or showroom mode, it will stay and not exit. It doesn't matter if it's unplugged or not. Look in user manual and see if it list how to exit. Good luck!
Jan 29, 2016 | Panasonic Genius Prestige NN-SE782S -...
Turn off demo mode
Jeanine,
Here is a copy of the manual for your microwave. Check page 11 for instructions on taking off demo mode. http://service.us.panasonic.com/OPERMANPDF/NNH735BF.PDF
May 16, 2015 | Panasonic NN-H765BF 1250 Watt Microwave...
How do I get out of demo mode/
  • Push the "Clock" key underneath the "Warm" key on the control panel three times.
  • Check that the display shows the time, then program the microwave to cook food as desired.
  • Read more : http://www.ehow.com/how_7262577_cancel-mode-panasonic-microwave-c994s.html
    Apr 17, 2015 | Panasonic Genius Prestige Over-the-Range...
    How do I turn off the Demo mode
    Press the timer/clock button 4 times. That should disable demo mode.
    Oct 20, 2014 | Panasonic Genius Prestige Inverter...
    Turn off demo mode
    Unplug it if doesnt its work it may be the pc board
    Sep 13, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
    Panasonic Dimension 4 Genius problem
    An internal fuse may have blown or the magnetron may have failed
    Apr 09, 2013 | Panasonic Genius Prestige Nnsd997s -...
    Microwave stuck in demo mode
    try unplugging it for 10 minutes. Otherwise, try looking at the instructions:
    service.us.panasonic.com/OPERMANPDF/NNC994S.PDF
    Sep 14, 2009 | Panasonic NN-C980 Convection/Microwave...
    Panasonic NN-T793SF Microwave Oven Logo
    169 people viewed this question
    Top Panasonic Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
