Question about Pyle Pl1156rd Led Brake Lights Light Bulbs Pl1156rd
No Brake Lights,cannot find the problrm,the fuses are not bad
    Problem Solver:
  • 16 Answers
Check the brake switch,its undernet the brake paddel
Posted on Sep 11, 2010
Ford 1989 f 250 auto
check p\brake pedal switch they go bad
Feb 17, 2014 | Ford F-250 Cars & Trucks
My running lights work my turn signals work why don't my brake lights
You either have a bad brake light switch or a bad fuse that powers your brake lights. Go to your fuse panel and check the fuse first. If it checks good then check the brake light switch. The switch will be located on the brake pedal at the top. There should be two wires into the switch. One will have power at all times. as you depress the brake pedal it makes the connection in the switch to the other wire which then sends power to the brake lights and illuminates the bulbs. Use an electrical tester to make sure you have power in and power out when the brake pedal is depressed.
Apr 07, 2012 | 1996 Oldsmobile Cutlass Ciera
Brake lights won't come on after changing brake booster on 97 gmc 1500. Also won't shift into gear.
check for a bad brake light fuse! if not the fuse, the brake light switch operates brake lights and if bad you will not be able to shift it out of park, as well as the brake lights not coming on.! because you have to put foot on brake to do so. if bad switch, it wont let it out of park. it could be just out of adjustment also!! good-day !
Aug 28, 2011 | 1997 GMC Sierra
What fuse is it for taillights and dome light 2000 ford focus
Running lights (left side): Fuse #47 -- Running lights (right side): Fuse #48 -- Brake lights: Fuse #54. Fuse panel is on the lower left side (underneath) the dashboard. NOTE: If it is your brake lights that are not working and fuse # 54 looks okay, check the brake light switch, it may have gone bad. Dome light is fuse #46 or #47 depending on model.
Mar 01, 2011 | 2000 Ford Focus
Brake lights not working All other lights are working
check the bulb... reccomend replacing brake light bulbs if they still don't work check the fuse for the brake lights
Jan 18, 2011 | 1995 Oldsmobile Cutlass Supreme
Have a 1999 Chev. Suburban. Problem is with brake lights. Top panel (on roof) works but neither side panel works. Replaced circut boards in tail lights, new bulbs, and all fuses are good. What next?
WITH A GOOD FUSE TESTER, TEST ALL THE FUSES FUSEBOX UNDER THE HOOD & INSIDE THE VEHICLE. IF THE FUSES ARE ALL GOOD WITH THE TESTER YOU MUST HAVE A BAD BRAKE LIGHT SWITCH OR A BAD TURN SIGNAL SWITCH. THE BRAKE LIGHT CIRCUIT GOES UP THROUGH THE TURN SIGNAL SWITCH & THEN TO THE BRAKE LIGHTS. FIRST OF ALL IS THE BRAKE LIGHT SWITCH GOOD ? THE ORANGE WIRE FEEDS THE BRAKE LIGHT SWITCH, THE WHITE WIRE PUTS POWER TO THE TURN SIGNAL SWITCH, SO THE LIGHTS CAN BE USED AS TURN LIGHTS OR BRAKE LIGHTS. , PUT A TESTER IN THE WHITE WIRE & PRESS ON THE BRAKE PEDAL. IF THE TEST LIGHT LIGHTS UP, BRAKE LIGHT SWITCH IS GOOD, BY THE WAY THE BRAKE LIGHT FUSE MAY BE LABELED" STOP", THE FUSE LABELED" BRAKE" IS FOR THE ABS SYSTEM. TO CHECK THE TURN SIGNAL SWITCH FOR BRAKE LIGHTS, REMOVE THE PLASTIC COVER FROM UNDER THE STEERING WHEEL, PRESS ON THE BRAKE PEDAL, PUT THE TESTER IN THE SMALL YELLOW WIRE, THEN THE SMALL GREEN WIRE. IF THERE IS NO POWER IN EITHER WIRE, THE TURN SIGNAL SWITCH IS BAD.
Jan 11, 2011 | 1999 Chevrolet Suburban
1995 ford tarus no panel lights or parklight nor brake lights at night time
the head lamp switch is faulty and replaced and that should correct the problem
Mar 16, 2010 | 1998 Chevrolet S-10 Pickup
Brake lights/tail lights won't work
tail light fuse and brake light fuse, and they are marked, if they are good then you have a bad light switch or a bad turnsignal switch assembly harness.
Jun 25, 2009 | 1994 Plymouth Sundance
Pyle Pl1156rd Led Brake Lights Light Bulbs Pl1156rd Logo
37 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
