Question about Cobra MicroTalk FRS 110-2 (14 Channels) 2-Way Radio
We have Cobra GA-CR? (not sure, 7-8 years old from Costco) handheld portable radios.One of them always has the static sound when turned on. They both work and we can call each other but the static is terrible. Is it the power saver not being turned on? The static radio has two lines at the top of the tower always on where the other does not except when transmitting. How do I change that? thx.
    Top Expert:
  • Cobra Master
  • 2,931 Answers
Contact your local retailer directly or online here: Support Cobra Electronics Corporation
Posted on Feb 01, 2018
SOURCE: Long range mode
we bought a cobra hl-200p its says 2mile range but it doest mit the standard range for about 50 feet we can no longer transmit and when we set to max range we only hear loud static can you help us on this problem? tnx we only have 2days warranty
Posted on Jan 14, 2008
Agent Ken
  • 250 Answers
SOURCE: transmitting
Hello lstimpson,
You may have the CTCSS privacy code function enabled on one radio and not on the other. This function keeps your radio's received muted unless it receives a signal from another radio using the same privacy code. If you have Privacy Codes set for radio A but not for radio B you will still be able to transmit from A to B but when you transmit on radio B your signal will not be heard on radio A.
Make sure that both radios are set to the same privacy code or that the function is turned off on both radios.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jul 21, 2008
vrc_tech
  • 109 Answers
SOURCE: Batteries won't charge on new cobra 2VP 270 radios
If radios are brand new then I would take them back to the store for warranty exchange. The other opton is to vist a local radio service center and ask the tech to jump the battery. if the battery falls below a certain voltage it might need a quick jump sart from a power supply with a higher voltage normally 12 volts works well...
Posted on Aug 20, 2008
  • 212 Answers
SOURCE: radio powers up but no sound
Check E-Bay if not check here. http://www.khulsey.com/rv_info/rv_cb_radios.html Hope that helps.
Posted on May 24, 2009
  • 50 Answers
SOURCE: Cobra LI7200
Please don't touch any internal adjustments. It is like a 10 digit combination lock that is set to open. If you start changing the numbers, you will never get it open.
I think the problem is with your tone coded squelch (CTCSS). Your radio channel is like a telephone party line. If your CTCSS is not on, everytime you turn your radio on you will hear anyone on that channel that is close enough to hear.
If you are trying to use these radios for serious communications, that will drive you nuts to hear everybody else talking but not about what you need to hear. To try to mitigate this problem, CTCSS was created. There are 38 different codes. If you for example set your unit to operate on code 11 and your other unit is set to operate on code 12, you could not hear each other.
Now let's add a third unit set to not use CTCSS at all. Neither one of you will be able to hear this third unit but he can hear both of you. Now you set the second unit to code 11 like the first unit. Now you will be able to hear each other. The third unit will still be able to hear both of you but since he is not transmitting code 11, you still can't hear him.
If you are hearing some traffic, it is because they have their CTCSS set to the same code that you are set to. Look in you operators manual for CTCSS Privacy Codes. Set your radios accordingly and I think you will be in business. Let me know if this doesn't take care of you problem.
Posted on May 29, 2009
Can't pick up any talk on my cobra 75 ws xt cb radio
Was your antennae set up professionally? You may have a short in the cable or connections or even a bad antennae and/or a bad match. Was it matched with an SWR meter? Have these checked out because it does sound like an antennae or cable/connector issue.
Jan 31, 2014 | Cobra 75 WX ST 40-Channels Handheld CB...
Need manual for cobra GA-CR WALKIE TALKIE
Cool, then please CHECK HERE (just thought I would scream the last two words like you did...)
Jan 12, 2014 | Cobra Radio Communications
My Cobra MircroTalk walkie-talkies aren't charging. The charge light doesn't turn on and I've made sure u turned Tue units themselves off. The model number is: GA-CQ
If your problem started after replacing the batteries (mine did), see this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html If that is your problem, you can also fix it by wrapping foil around the bottom of the battery that makes that touches the bottom side charging contact.
Oct 19, 2013 | Radio Communications
I have a cobra 29 with echo, tweeked and tune. I can transmit strong and I hear those who speak to me but I dont have any static like you do with a new radio. Is this something I need to worry about as Im...
Make sure the squelch is turned all the way to the left, the RF GAIN is turned all the way to the right. The cobra 29 has a very good noise blanker, Turn the ANL/NB switch to off, You will probably hear a Lot of static, As long as you have a good ground on the radio and antenna, and your SWR is 1.5 or lower, you need not worry about static.
Oct 05, 2012 | Cobra 29 LTD CB Radio
When we push the button to talk, we get a low frequency squeal, and the other CB radios receive a squeal. We have tried adjusting the sqelch, no fix. It seems to disappear sometimes when you turn it on and...
Hi,my name is John. Welcome to FixYa. Do you hear voice in radio? May be to close to each other. Let me know how it goes. Good luck and thanks for Choosing FixYa ..John sounds like feed back from speaker.
Nov 06, 2010 | Cobra Road Trip 40-Channels Handheld CB...
They dont reach over a klm,they where to be 36klm
Handheld radio range has always been way over sold. The biggest problem with handheld radios is not as much the power output but the inferior antenna system. To be able to predict radio range you must know transmitter power, receiver sensitivity, receiver selectivity, gain and height of each antenna system, distance and obstacles between. I feel sure that you are probably getting true expected range. Sorry!
Jun 26, 2009 | Cobra 22 CHANNEL 2-WAY RADIOS
Cobra 75 wx st
Hi and welcome to FixYa,
Initially, pls a couple of ideas you may want to consider/explore or try/check:
  • PA/CB switch must be to CB;
  • RF Gain max clockwise;
  • Squelch counter clockwise;
  • Volume to your desired level;
  • Mute (off);
  • external speaker/speaker connection;
  • audio amp, verify if there is TX modulation;
  • antenna, antenna cable. SWR should be low.
Good luck and Thank you for using FixYa. Happy New Year.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate this at all. Cheers.
Jan 01, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Cobra Cb handheld radio model: HH-35 doesn't work
Open up the back of the radio and check the solder joint from the antenna connector. I had same problem and it was this.
Mar 23, 2008 | Cobra HH 38 WX 40-Channels Handheld CB...
Cobra MicroTalk FRS 110-2 (14 Channels) 2-Way Radio Logo
181 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
