Question about MGA Entertainment Bratz Secret Stylin' Safe
Bratz safe accepts voice activated and keypad entered code but does not unlock. Reset button does nothing
2 Suggested Answers
janrom2321
  • 74 Answers
SOURCE: Bratz laptop turns on, asks for game code but
if you go online to bratz.com seatch the iteam you purchased then you should be able to download the manual ofline.
Posted on Sep 13, 2009
My combination will not open my canon safari 24 gun safe
The Canon safe, if not modified, comes with a digital pushbutton keypad that activates the interior release mechanism. Without exact details (clicks?..buzzes?..beeps?..totally dead?) an answer is hit or miss.
Adding to the obvious..a good battery, no visible damage, forgot the combination, wrong button sequence...
1. the keypad only sends the open signal for the correct combination after keypad is pressed.
2. if it accepts the combination (no error beep), is the signal accepted to unlock.
3. is the interior mechanism trying to unlock.
If you can determine which stage is failing..it will determine if there's a fix.
If all three are working, you hear a little click after..the door/lever may have pressure on it.
If any one of the three cannot be confirmed..no entry with the pad!
Oct 07, 2016 | Home Security
How do i change the code on a s25e digital safe i cant find the book
if its like my old woolworths one, open the door and press a red reset button on the inside of the door, close the door and dont lock, put in the 4 numbers u wish a press a A button on the keypad, or whatever ur enter button is, then lock it, then press the 4 numbers again and the A button or enter, a light should stay on and unlock :)
Feb 21, 2011 | Safe International Electronic Gun Safe...
Does not overwrite old codes, just keeps accepting new ones. How can I clear all existing codes?
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Jan 27, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Unit is functioning o.k., but getting green light flashes about every 10 seconds. Batteries and connections are o.k.. Can't find anything in the manual or on Weiser website as to a solution.
reset all code and retry...
Good lock
Good unlock
Dec 31, 2010 | Weiser Lock Powerbolt 1000 Lock
We are trying to reset a security code for our existing weiser lock and it isn't taking the new code entered.
Good lock
Good unlock
Nov 08, 2010 | Weiser Lock Powerbolt 1000 Lock
The original code will not clear from my Weiser lock electronic lock. I have entered multiple codes and the original still stays. How do I get the original to clear.
I guide you...
May 04, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
How to change the keypad code on a 2001 mercury grand marquis
look for the permanent code on the plastic card in the owner manual packet. Or, pay dealer to extract code from computer.
Keyless Entry Keypad Code Programming NOTE: The system only allows one code to be programmed.
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds after activation will erase the stored customer code . The door locks will lock, then unlock, confirming the code is erased. The existing code will not need to be erased to program new a code.
  1. Within five seconds, enter the new five-digit keyless entry keypad code. The door locks will lock and unlock to confirm the new code is programmed.
Feb 08, 2010 | 2001 Mercury Grand Marquis
Have a Rona electronic lock (Weiser) and the key works... will lock electronicly... but do not know the code... I have removed it from the door and replaced, but is there a way to reset the code?
I guide you...
Jan 23, 2010 | Weiser Lock Powerbolt 1000 Lock
How to reset keyless entry on 2005 taurus
To reset the personal code you will need the permanent code supplied by Ford. This will be on a white card left in the clove box or in the owners manual bag. This can also be retrived if you go to a Ford dealer. Expect to spend around $50 at the dealer unless they can help you out. Once you have that do the following. Good luck.
1.Enter the permanent factory remote keyless entry (RKE) keypad code.
2.Press the 1/2 button within 5 seconds to activate the programming mode. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
3.Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Feb 23, 2009 | Ford Vehicle Parts & Accessories
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
MGA Entertainment Bratz Secret Stylin' Safe Logo
328 people viewed this question
Top MGA Entertainment Toys Experts
Andrew Taylor
Andrew Taylor
Are you a MGA Entertainment Toy Expert? Answer questions, earn points and help others
