Question about Panasonic Home Theater System System
I have a Panasonic SC-BT100 w/ wireless remotes. Rear channels are intermittently going on and off. Is they Digital trans. card defective?
    President:
  • 2,777 Answers
It sounds like the card has failed, you can test this by attaching your rear speaker to the front left and right channel on the receiver. If the speakers work without issue you know those rear channels are failing. If they still have an issue, try different speaker cable, after a while (especially in humid environments) speaker cables get corroded and start to have issues causing intermittent transmission.
Most likely though it is a problem in the receiver, but these tests can help you determine for certain.
Thanks, let me know if this doesn't help
Tim
Posted on Sep 11, 2010
I have a panasonic sc BT 100 blu ray home cinema system, the iPod and optical inputs appear to not to be working, are there any internal fuses that could have blown
Inputs are not fused. Have you looked at the manual(s)?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SC-BT100-Home-Theater-Systems-manual/id/17669ag210/t/2/
Digital inputs need to be assigned. The optical cable must be routed with no tight bends.
Jun 29, 2011 | Panasonic SC-BT100 Theater System
Just purchased SBHS100AE-K rear speakers to connect to my SC-BT100. I want to connect them wired rather than purchase the wireless transmitter, but I can't figure out how to connect the wired rear speakers...
This unit is not as flexible as traditional receivers are as far as speakers are concerned. Speakers are labeled and *must* be connected to the correct speaker terminals.
Upon reading the manual - it is quite apparent that the only provisions for rear surround speaker connections is <i>only</i> via the optional wireless transmitter / receiver hardware. The optional digital transmitter is connected via a proprietary plug on the rear of the SC-BT100. The optional receiver amplifies the received signal and passes it to the connected surround speakers. I would bet that there are no provisions for amplifying a surround L and R speaker channel inside the SC-BT100, and that it only provides a low level (like a "tape out") or un-amplified signal to the transmitter plug. Even if you were to manage to get the surround speaker connections made up there - you would not be able to hear anything from them - as there is no amplifier. The amplifier is contained in the wireless receiver, and is largely why it requires a connection to house current.
Unfortunately, I doubt you'll find a way to listen the surround channel audio from the SC-BT100 without the optional transmitter / receiver and the integrated amplifier.
You can review the manual like I did here:
http://service.us.panasonic.com/OPERMANPDF/SCBT100.PDF
I hope this answered your question.
Jun 11, 2010 | Panasonic SC-BT100 Theater System
When i turn up the volume on my home theater it goes to maximum by itself, and does the same on minimum side!!
Turn unit off, then Press "Play/Pause", "Stop" and the "Power" button on the unit (not on remote) ALL AT THE SAME TIME. This should fix it. Also, download the firmware update (Google "firmware update for Panasonic SC-BT100 and follow the link to the Panasonic support site)....since I updated the firmware, mine hasn't done this again.
Feb 02, 2010 | Panasonic SC-BT100 Theater System
Can u program Panasonic SC-bt100 without remote ?
Not that I know of....the remote has options that aren't on the physical unit so programming must be done with remote.
Jan 01, 2010 | Panasonic SC-BT100 Theater System
I cannot get a picture from my sc-bt100 on my screen the sound is working no problem checked all leads and connections
How are you hooking it up? To what kind of TV? Best connection for SC-BT100 is via HDMI out on SC-BT100 to HDMI in on TV, otherwise you aren't getting full HD output. Make sure your TV is set to correct input source.....
Dec 27, 2009 | Panasonic SC-BT100 Theater System
I got a panasonic sc-bt100 from sears used but i cant connect the rear speakers i think im missing a part do you need to put something on the dvd player so the rear speakers could work?
There should be a "module" that you slip into a slot on the back of the main SC-BT100 unit...this is the transmitter that sends the signal to the rear speaker unit. The rear speakers, while "wireless" to the main unit, are wired to the separate unit that should have come with your set-up.
Oct 02, 2009 | Panasonic SC-BT100 Theater System
SC-BT !00 Panasonic wireless speaker connection won't link
If you go into the set up menu and go to the speakers set up - it only shows the right, left, centre and subwoofer on the screen. You need to go down to the box below these speakers and activate the rear speakers which are not shown. The wireless section will then light up w1/2 on the display at the front of the scbt100 - i had to call panasonic to figure this out and they advised me it was missing from the instructions!!!
Feb 23, 2009 | Panasonic SC-BT100 Theater System
When volume button is pressed it does not stop going up or down
You can also use the cancel button on the SC-BT100 remote to keep the sound volume from accellerating up or down if you don't want to take the time to unplug for the 5 minutes, if your watching something and don't want to miss it.
Jan 18, 2009 | Panasonic SC-BT100 Theater System
Wireless speakers won't connect
You try upgrade the main set to 5.1 or 7.1 channel is it?
If the wireless is green light mean the main set is recognize the wireless.
You need to setup the speaker output from main set by "Setup" button on remote control.
Can refer Operating instruction manual in main set.
Nov 29, 2008 | Panasonic Home Theater System System
Panasonic Home Theater System System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
