Question about Hitachi 43FWX20B 43" Rear Projection Television
How can chang sony tv stk ic - Hitachi 43FWX20B 43" Rear Projection Television
  • 63 Answers
If it is a sony check to see if any of those little green resistors are blown first. most sonys have the stk chips on the main deflection board.they will be next to each other with a big heat sink on each.have a soldering and desoldering iron ready as well as tape and marker for the wires.. remove the wires from the board you dont have to take the board all the way out. start desoldering each pin. if some pins are stuck just touch the pin with the iron. clean the heat sinks.apply themal paste to the new ics. put the new ics through the holes and start soldering. this part can be tricky. put the tip on the pin the solder will flow just quickly remove the solder then the iron 36 times and your done.
Posted on Sep 11, 2010
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
Distorted picture and color
This kind of problem occurs due to failure of convergence output ICs in Sony KP-51HW40 tv.
Replace convergence output ICs to solve tv problem.
This set uses two of the STK-392-570 IC chips for this (convergence problem)
Local tv repairman will do this job if you have no experience of electronics stuff repair.
Dec 22, 2010 | Sony KP-51HW40 51" Rear Projection...
I have a sony kp-51hw40 that I just received
This problems also cause by the 2 STK convergence ICS and some or all it resistor are dead.Require changing the 2 STK convergence ICS and some or all it resistors will solved this fading out and shuting down.
Jul 11, 2010 | Sony KP-51HW40 51" Rear Projection...
Double photo
Replace both of your STK ICs STK392-110s use 150s Mats has Them 1-800-628-1118
Jun 02, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
Convergance- Red X will not move to make crosshairs white. Picture is doubled with red and blue. TV is a 55 in Mitsubishi VS55601.
This problem is related to the Convergence controller IC called STK.It must get malfuntioning replace the STK IC with the same numer IC. But one thing is importent that there must be two IC STK's and you have to change both of them.
Thanks
Oct 11, 2008 | Televison & Video
The Blue and Yellow colors on the left half of the screen(looking at TV) will not adjust correctly. Sony Rear Projection HDTV-Ready TV about 7 years old...
its the problem of convergence on your television.so resolder convergence STK ic's. if that does not work, change (STK-ics).
they ar located on the main power supply board and there are two such ics on the board replace both the ics.and easily available in the local electrical shop.
Sep 24, 2008 | Televison & Video
KP46V15 Convergence problem
You must have checked fusible resistor?
check convergance control panel and check voltage supply to this board.If voltage are o.k than you have to change convergance control ic which is smd ic and its on the control board.
Gopal
Dec 10, 2007 | Sony KP-46V35 TV
Hitachi 43FWX20B 43" Rear Projection Television Logo
70 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
