I have a syntax brillian olevia 42 in. lcd tv the blue light comes on after a while starts to blink. but how do i get it to power on
    President:
  • 1,961 Answers
There are several parts of the TV that we need to check with regards to this problem..
1.the power supply you need to open up the cover of your TV take out the power supply disconnect all the output connectors(mark the connectors do not interchange them) and plug in to mains supply and measure the output voltage you shpould have an output of 5v for the main CPU board.12v for the sound/audio board and 24v for the backlight lamp. Use a voltage tester to measure them.
2. The back light lamp be sure that lamps are lit .usually an lamp nearly to be busted blinks and then out.the lamps are located at the top and bottom of the screen.
3.the inverter board.this inverter board gives a high voltage supply the lamps.the input voltage of inverter board is 24v and the output voltage feed to the lamp is 100vac-200 volts ac so be carefull when testing the output.most common error of the inverter board is the poor solder on the output termina and the input terminal resoldering this connectors will solve the problem
..good luck hope this helps yoy .Post back a message if you have other question.
please do click the 4 thumbs up button for my effort this helps me keep going!
Posted on Sep 11, 2010
How do I fix my OLEVIA 42" flat screen??? Power light comes on the fades
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 28, 2014 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Standby light is on,but my olevia tv will not turn on.
No, someone will need to open set and check voltages etc and also look at power board to see if any puffed up bad caps like these:
Apr 18, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Olevia LCD HDTV 242tfhd will not turn on.
See solution above (from John Adams) if that doesn't work it may be the power board which is available on ebay for $69 incl. shipping. Good luck.
Mar 09, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
My blue powerlight isnt working on my olevia tv it is 3years ol what could it be
If the tv is infact turning on eventhough the power light isnt, its the bulb for the powerlight itself
Nov 20, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Remote codes for olevia tv
I just bought a Sony RM-VLZ620 for about $20 and it comes w/ Olevia codes.
Oct 21, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
My Olevia 242TFHD will not turn on. The blue light goes off but the tv does not power on. If I unplug it and plug it back in the blue light will come back on but when I try to power it on it never turns on
The tv have a Tuner board problems,this is the board,that take in the broscasting signal cable.Tries unplug,replug about an hour later.The tv should reset it self and work.Not than tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 08, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Picture rasterization
It sounds like the LCD controller board problem, usually if you cool it down the problem will go away, and comes back when it heats up again.
Nov 23, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Olevia 42 inch Flat Panel has power supply issue... Blue light does not come on and tv does not turn on... I have tried all different things to get tv to work with no positive results
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Nov 04, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
