Question about Behringer Pmp3000 16 Channel Audio Mixer
My mic output is very weak. Music comes out great. I have to set the levels all the way up to get any mic sound and usually there is a lot of clipping. You need to almost scream to get any sound with a mic. if I need to use a pre-amp, how would I connect it? It's the europower pmp3000
  • Behringer Master
  • 5,603 Answers
Thiis amp has plenty of gain for mics. Make sure your mic has a good XLR to XLR cable (balanced) and connects to the XLR input connectors. If you have 1/4 inch jack cables that aren't TRS balanced on the mics, get rid of them and get XLR's.
Then push the PFL button down (LED will light red) for a single channel with a mic and adjust the trim (top knob for the channel) so that the level peaks without clipping on the main LED display when highest input to the mic is being generated. You should not get clipping then during operation.
After that you use the slider tio adjust the level for the mic. The MAIN slider should be at least up around -10 to zero during operation. If your main slider is way down, then you haven't balanced your channels properly. Do the same for each channel as the instructions for the mic above. If the gains of the other inputs are too high and the MAIN slider too low, this is what is causing your problem.
Typically the trims for mics like Shure 58 are about 3 o'clock.
High level guitars may have trims anywhere from 9 to 3 o'clock.
Ideally you will want your channel sliders to be between -10 and zero.
Posted on Sep 11, 2010
  • pete brown Aug 07, 2013
    i have the same prob. i use a shure sm58 and the level set(trim)must be almost fully clockwise.yet it works perfectly on my old studiomaster.i hear its the poor pre amps in the pmp3000.
I have a Peavey XR 8600 PA, I have tried adding an external vocal effects module into a mic line but it drops the output volume of the entire PA by about 75%. Any ideas why this is?
Well, I would say it isn't dropping the level of "the whole pa", it is just dropping the level of the input you have plugged the fx into. Check the settings on your fx unit, there are usually input, output and mix controls that are independant of "the pa" and affect the amplitude of the signal going into your mixer from the fx unit.
Nov 01, 2017 | Peavey Music
Why does my mackie cfx12 mkii have low output across all 8 xlr inputs at unity gain with distortion above that?
Where are you getting the low output? It would be very strange if all channels failed in the same way so it is probably something common to them all. Can you get the clip light to illuminate at all by turning the gain up on a mic channel and shouting into the mic? You are referring to the gain at the top of the strip not the slider aren't you? What happens if you assign a channel to the other sub channel, does the level come up through that? What happens if you take the output from the aux send and you send signal there, is it the same issue?
I may be completely wrong but I suspect if it is only mics that are causing a problem you may have the routing set up wrong or not set a level somewhere else right.
Aug 10, 2014 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
We have a 150. When we add a MP3 it sounds great until you add voices into a mic then it fades out. What could be causing this?
Turn the VIP level all the way down for the microphones you are using over the Mp3 music. If the VIP levels are up, the music will fade out so you can make an announcement.
Jun 10, 2011 | Fender Passport Deluxe 500watt Sound...
When we are trying to get a reasonable level of sound for vocals before it gets loud enough to be able to hear clearly with the band playing it starts to clip at the speakers now we are only using this set...
Proper level setting of the mixer is important. HOWEVER if the clipping is occuring at the speakers the only possible problem MIGHT be that you have a supersonic feedback that is saturating the speakers above your hearing range, Be sure you don't boost the highs too much with the EQ as this can cause the feedback that you can't hear. Also make sure that you power the speakers from the SAME receptacle as the mixer, even if it means running an extension cord to bring power to the mixer. This is to avoid a low frequency hum and common mode distortion/damage. A low frequency hum could cause the clipping.
It would be a good idea to get a sound meter to check the sound level. You should be able to reach 85 Db from this system without clipping. If you need more than that, you MAY need more speakers if the band instruments are too loud. Also if the band has amps that get into the vocal microphones that adds to the clipping level... make sure the mics don't "hear" the band instruments. Make sure your speakers are toward the audience from the mics to avoid the supersonic feedback problem. If the vocalists can't hear themselves with that configuration you need to set up seperate stage monitors.
There are some pretty good videos on YouTube about proper mixer level setup.
Jan 30, 2011 | Behringer Xenyx X2442USB / Harbinger...
Mic output of my pmp3000 is weak,levels must all the way up to get any mic sound louder,Im using balanced xlr's for my mics, Is there any adjustable sensitivity adjustment inside the mixer? like the one...
Some mics will require the trim gain to be full on. Check the mic gain by pressing the PFL for each channel and set trim to be below the clipping level with maximum vocal into the mic.
There are some low output mics that may be inadequte as far as output goes. Shure SM58 are industry standard mic... If you don't have one to try, borrow one to test with.
After that, the slider, EQ controls and the MAIN sloder has all the control.
Sep 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Mic output of my pmp3000 is weak,levels must all the way up to get any mic sound louder,Im using balanced xlr's for my mics, Is there any adjustable sensitivity adjustment inside the mixer? like the...
The answer to your question is NO, there is NOT an internal adjustment.
For many mics the trim is used full clockwise. Some higher output mics I use the trims are run at 3 o'clock which is mostly turned up. This is NORMAL for most mixers. If you don't have enough mic gain relative to other inputs, the fault is balancing the other inputs down and using higher setting on your MAIN slider.
If you use 8 ohm speakers then you can expect to get about 200 Watts of audio per side with this amp. You can get about 400 Watts RMS (600 Watts peak) using 4 ohm speakers.
The efficiency of the speakers makes a lot of difference in the sound level output/
I have purchased a beheringer 1832fx usb mixer and I have connected my computer to my mixer that has a usb interface on the back in order to play my backing tracks, music, via my computer, and when I turn...
The main mix controls ALL outputs simultaneously.
The mic channels are controlled individually by the sliders.
It sounds like you are on the verge of feedback where the mics are picking up the PA speakers.
Make sure you have loaded the support SW and make sure you have disabled ECHO as the mics may be looping back through the computer causing the rattle.
Sep 06, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
How do i connect yamaha mixer to pc or yamaha receiver
I am sorry to disagree, but some information in the previous post is INCORRECT. DO NOT connect the output of the mixer to the MIC input. The mixer generates LINE level output that should go to the LINE-IN on the sound card. If you connect the mixer to the mic input, you will damage the sound card. MIC level inputs have an additional amplification stage.
Dan
Mar 09, 2010 | Yamaha Mg102c Stereo Mixer
Korg pa800 mic input makes funny noise
First turn the unit off then rotate the input level volume control. If it feels loose pull up lightly on it as you do this. Also rotate all your controls that you don't normally use a lot. Chances are the pots are dirty. If that doesn't help you might want to check all the connectors inside the unit if you feel confident enough to go poking around. Other wise I suggest that you find a shop that will fix the problem. If you do go poking around make sure the units unplugged and that you have grounded yourself against static discharges.
Nov 26, 2008 | Korg Pa800 Synthesizer
Behringer Pmp3000 16 Channel Audio Mixer Logo
288 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
