Question about Stanton T.50 Turntable
The turntables dont spin wen u press play - Stanton T.50 Turntable
    Champion:
  • Stanton Expert
  • 271 Answers
Hi, the drive belt has come off or stretched beyond use. Remove the platter to check. We have drive belts in stock for this player. Styluscity@gmail.com
Posted on Sep 13, 2010
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Apr 08, 2013 | Audio Players & Recorders
Would changing the belt help as my turntable plays too fast.
A lot of turntables have two belt positions on each pulley. One for 33 and one for 45. I would check to make sure the belt hasn't slipped into the 45 position.
Jan 13, 2013 | Audio Players & Recorders
Im playing my SL-1200MK2 threw serato and it when i press play to make the record spin serato pick up that the record is slowly spinning backwards? and no noise is coming from the record
do you have your timecodes set properly and configured with serato? that could be the issue try adjusting the timecodes w serato and basically re sync them. if this doesnt help please let me know
May 11, 2011 | Technics SL-1200MK2 Turntable
Turntable turns on, but it when i press play the plate doesnt spin. i noticed it budges like a mm but definetly not working
Turntable Drive Belt
The chances are the rubber drive belt has either broken or stretched so that it has fallen off the drive pulleys.
You will need to gain access to the underside of the turntable to replace it.
With most turntables the process will be to secure the tone arm (a rubber band will do the trick) before turning the whole thing upside down and unscrewing the base.
Replacement drive belts are easily available on the internet. Search by make and model number of your turntable
Feb 09, 2011 | Technics SL-1200 Turntable
The platter on my 15 year old SL-BD22 turntable does not move when I move the tonearm into postion to play a record. Do I need a new motor? If so, where can I find the original equipment, what will it...
Not certain you will need a new motor - yet- !
First since the arm movement turns on the turntable some kind of switch must come into play. These break or move out of poistion, so check that first. The access I suspect will be through the base of the turntable.
As most of these types of turntables use a 12 volt motor, you can attach a 9 volt battery to it's terminals and that should make it spin. If it's dead sluggish or doesnn't spin fast or at all, it's dead. If it does spin then there's something up with the power supply section to it.
Jan 23, 2011 | Technics SL-BD22 Turntable
Turntable platter doesnt spin when you press start/stop
Is your turndable belt driven? If so replace the belt.
Jun 05, 2010 | Numark TTX Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
My turntable has stopped spinning when i press start. when i stop it it spins back for a sec then nothing.when i take the plate off the turntable the bit that would spin seams like it can't move free is...
Since it's Direct Drive there's no belt to fall off. There is an electronic brake.
Could your problem have something to do with the Reverse function? Check the L.E.D. Perhaps cycling it will help.
USING THE REVERSE BUTTON:
1. Press the REVERSE (17) button to reverse the rotation of the
PLATTER (2) (the REVERSE LED (17A) will light while in reverse
mode). Press the REVERSE BUTTON a second time to return to
normal play.
http://www.geminidj.com/disc._prod_manuals/TURNTABLES/PT-2100/PT-2100.pdf
Mar 07, 2009 | Gemini PT-2100 Turntable
Stanton T.50 Turntable Logo
120 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
