Question about Dishwashers
KHi Have a Kenmore dishwasher model number 665.13842K601. Need the reset sequence for the flashing "clean" button.
  • 4 Answers
SOURCE: Kenmore Dishwasher model # 665
replace control board
Posted on Feb 16, 2008
SOURCE: Clean Light Flashes
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Mar 24, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Dishwasher power surge results in flashing clean button
I'm not sure what the sequence would be on your particular model as Whirlpool dishwashers can differ in operaiton. However, if you remove the lower kick panel under the dishwasher door, there should be a tech sheet either directly behind the panel, or tucked inside the door. The tech sheet will list all troubleshooting tips and any fault codes that the owner/operator's manual does not list. This is the SAME sheet the repairman will reference when they come to your home on a service call. Please let me know if you still require assistance. I hope this helps you.
Posted on Oct 22, 2008
  • 530 Answers
SOURCE: Kenmore 665 15899
ok usually it's heated dry and normal until all the light light up then hit cancel . but if the clean light is blinking you probably have a problem with the heating element
Posted on Jan 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: kenmore 665 dishwasher will not drain
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 08, 2009
My Kenmore Ultra wash dishwasher will not cycle.....the green clean light keeps flashing. How do I reset the cycle?
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Kenmore Dishwashers
My newer model dishwasher has locked up. Clean LED light continues to blink. Any ideas? This happened once before and a sequence was given to me that I no longer had :(
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 07, 2011 | Dishwashers
The clean light is flashing on a whirlpool dishwasher-model du1048. The manuel says the dishwasher has malfunctioned and to check the heater circuit. How do I do that?
Kevin
Feb 17, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
My dishwasher is flashing clean and will not stop , no other buttons respond
Kevin
Feb 15, 2011 | Whirlpool Dishwashers
Clean button won't stop flashing and it won't start, got interrupted mid cycle.
Kevin
Feb 05, 2011 | Kenmore 24 in. 17039 Built-in Dishwasher
Dishwasher will not start. The clean light is flashing on and off. If I push the cancel button it appears to be draining but there is no water in the tub and it just continues. When I push the start...
Kevin
Jan 20, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Dishwasher clean light will not stop flashing preventing further input and dishwashing
Kevin
Dec 14, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
Clean light is flashing machine won't start
Kevin
Dec 09, 2010 | Kenmore Dishwashers
Clean cycle light is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 22, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
What is the sequence to reset our kenmore 16052
Hi
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 26, 2010 | Kenmore 24 in. 16052 Built-in Dishwasher
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
