Question about Audiofonics ADF-272 Car Speaker
Im building a custom speaker enclosure and I would like to know the exact volume needed for these speakers I need the volume for sealed and for ported cause I will be doing both right now I have a plan marked out already with a inside volume of 1.39 I need to know if this is what I need for perfect speaker response??
The Marv
  • 72 Answers
SOURCE: Enclosure type
Sealed box and somewhat large if they are 12's I usually try to get 3 cubic feet overall internal dimensions and generally the inside dimensions will be 13" tall 32" wide and 13"-14" inches deep. with no divider and make sure the box is sealed. Personally I like to phase the speakers backwards. Gives the bass a little more rumble.
Posted on Jan 05, 2007
hidalgo1301
  • 5 Answers
SOURCE: Cubic inches of a Audiofonics 12
You should be able to download the owners manual for these speakers. The manufacturer will give detailed specs. on the type and dimensions of recommended enclosures for this particular speaker. If nothing is available to download, you could try to contact the manufacturer directly.
Posted on Jan 04, 2008
sticky92505
  • 77 Answers
SOURCE: I am trying to find specifications and optimum enclosure volumes.
visit the12volt.com, or i think that is what the url was. been a while but my buddy was an installer and he swore by the website.
anyways just trying to be helpful
Posted on Mar 13, 2009
etirbynnor
  • 655 Answers
SOURCE: need help im planning to build a enclosure for my
Hello marne_glenn,
Here's a link to Lightning Audio's manual for the S3.10.4.
The minimum recommended size for a sealed enclosure is .5 CuFt. There is no recommendation for ported.
Hope this helps.
Posted on Jul 29, 2009
  • 16 Answers
SOURCE: i have an ford falcon ba xr6 turbo UTE i am
the material you should use is MDF board you can purchase it at you local wood yard. i believe the kicker solo baric the the dem is 1 sq ft inside the box per sub i would recommend you go to the kicker solo baric web site they give you the dem for each sub. hope thius helps
Posted on Feb 28, 2011
12 inch sub(JBL) in box with a 500 watt pioneer amp, sounds good with some types of base. would you cut a port hole in speaker box?
riverray1969 it would help if I knew the exact model number of that JBL sub you are referring to. With that info I can provide exact specs.
Basically, you need to build/modify an sub enclosure that is suited for the sub, the music you mainly play, and vehicle tuning. Generally, sealed enclosures will provide tighter bass response and get decently loud. Some would argue that it will give you greater sound quality. A ported enclosure will give you a louder more booming sound. That depends also on where the port is tuned (ex. 32 hz, 36 hz, etc ). You need to make sure that the enclosure meets the sub's airspace requirement as well. A customized well made enclosure is just as important as the sub you put in it.
Oct 16, 2012 | JBL P-1020D Car Subwoofer
I have a Volfenhag ZX 4810 subwoofer, and it didnt come with any instructions, specification sheets, or literature of any kind. I want to build a custom box for it, but I need all the specs.I've googled...
I know this is really late. Hope it might help somebody. I just purchased a zx4810. For a sealed enclosure, 38L is recommended. Now I've got to convert litres into cubic feet.
Apr 03, 2011 | Volfenhag ZX-4810 10" High Power Car...
Hi i have a 15"w3-d4 jl audio sub,can anyone tell me what size antype box i should use ie sealed or ported and the box dimensions
I've had a look at the JLaudio website and they recommend 2 box designs, a ported and a sealed.
The sealed box needs a volume of:
2.125 ft3 or 60.2 litres.
To get this you would need to build the box to these dimensions:
22" x 16" x 14.75" or 559mm x 406mm x 375mm
The ported box needs a volume of:
3.50 ft3 or 99.1 litres.
24" x 19" x 18" or 610mm x 483mm x 457mm.
The port needs to be:
3.0" x 10.9" or 76mm x 277mm.
The enclosure recommendations listed above are external dimensions which assume the use of 3/4" (19mm) thick material. If you are using 5/8" (16mm) thick material, subtract 1/4" (6.5mm) from each dimension. Do not use any material with a thickness of less than 5/8" (16mm) as this may compromise the rigidity of the enclosure.
• All enclosure volumes listed above are net internal volumes! Driver displacement, port displacement and brace displacement must be added to obtain the final gross internal volume. All enclosure dimensions above have already taken this into acount.
• When using two subwoofers in a common enclosure simply double the required volume and, in the case of a ported enclosure, use two times the recommended port(s). Likewise, when using three subwoofers in a common enclosure simply triple the required volume and, in the case of a ported enclosure, use three times the recommended port(s).
• We recommend the use of this speaker in a bi-amplified system using high-quality satellite speakers and a high-quality amplifier. We do not recommend the use of this subwoofer with a passive crossover (coil), as this type of device will adversely affect performance.
As you can see it all depends on the space you have available, whilst the vented box will give you a more efficient bass responce especially with the low range frequencies.
If you to go and look at the information about your sub woofer and find out all the information about building or buying the correct enclosure then this is the link to the pdf file I found:
The enclosure info is on page 3:
JL AUDIO 15W3 Tech Specs and box info.
Warm regards
Mike
Oct 12, 2010 | Jl Audio 15W3-D4 Car Subwoofer
S10L7 displacement
Recommended Sealed Enclosures – Moderate Efficiency
  • 0.66 cu ft is the displacement of the sub
  • S10L7 .66 cu.ft. Power Handling = 600W 1.0 cu.ft. Power Handling =600W
  • 18.69 l 28.32 l
The following page shows examples of the minimum enclosure sizes for each of the Solo- Baric L7s. Panel dimensions assume 3/4" wood thickness. 5 Panel dimensions for minimum recommended enclosures: Model Volume (cu.ft.) Panel A Panel B Panel C S8L7 0.33 10"x10" 10"x8" 8"X8.5" S10L7 0.66 12"x12" 12"x10.5" 10.5"x10.5" S12L7 0.88 13"x13" 13"x11.5" 11.5"x11.5" S15L7 1.5 16.5"x16.5" 16.5"x11.5" 15"x11.5"
Jun 03, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
What is the optimal volume for a speaker box for two Pioneer TS-W26C sub woofers? I know that enclosure speakers have an optimal volume for the boxes, however, I can not find out what the optimal volume...
try this site very hepfull if you can find all the speakers spec's.http://www.ajdesigner.com/speaker/ajvented.php . if you have the latest pioneer speakers they were designed for small enclosures if you imput speaker code in to google search you should find all the details you need .
Sep 05, 2009 | Audio Players & Recorders
Need help im planning to build a enclosure for my s3.10.0 subwoofer, can someone advice what type of enclosure and what size it will be. Tnk u very much! hoping for good advice.
Hello marne_glenn,
Hope this helps.
Jul 29, 2009 | Lightning Audio S3.10.4 Car Subwoofer
I need an enclosure for a power acoustik mofo 12''.
Hello miles_jamike,
Power Acoustik recommends a 1.25 CuFt sealed and 2.0 CuFt ported enclosure for the P1, P2 and P3 subs. The PSQ needs 1.25 sealed and 1.75 ported. In physical size, this translates into about 16X12X14 for sealed and about 30X42X15 ported.
You should try to stay pretty close to the recommended enclosure volume for best performance. A good volume calculator is located here on the12V.com website. Just enter the proposed width, height, depth, and material thickness and click the "=" to get the CuFt.
If you are building (or having built) a custom enclosure for a specific location in your vehicle, all you need to do is stay very close to the volume recommended.
If you intend to purchase a generic enclosure, the Goldwood shown here at Parts Express is an exact fit. Atrend also makes good generic enclosures, their model 12SAL in a sealed box with 1.20 CuFt and the 12LSV ported with 2.50 CuFt would be good choices.
Crutchfield has both generic and custom enclosures made by JL, MTX, QLogic, and Bass Slammer. Crutchfield has excellent support. They will respond promptly and positively to your phone or email inquires. If you have never ordered from them, you can use a "friend referral code", such as mine, which is: p7sdj-hrx8q-9800g, and on any order of $200 or more, you receive a $20 discount. And I get a $20 credit on a future order. Also, many orders qualify for free shipping.
Hope this helps.
Apr 29, 2009 | Power Acoustik MOFO-12 Car Subwoofer
The best bass in this case
HERE is the owners manual for your sub.
If looking for LOUD, ported enclosure is the way to go.
If looking for accuracy, build sealed.
You dont have enough depth for an isobaric setup.
using the maximum dimensions given, 8x13x41, the volume of the biggest enclosure you could make (assuming 3/4" MDF material) is 1.7cu ft.
To tune this 1.7cuft box around 50Hz, you need (1) 4" round port 5" long.
MTX recommends an enclosure of 2cuFt ea. You will only be able to use 1 subwoofer in this application.
Even a sealed enclosure is recommended 1.25cuFt.
You can shove 2 in the vented enclosure, but you may not be happy with the outcome.
Thanks for using FixYa - A Fixya Rating is appreciated!!
Jan 27, 2009 | Car Audio & Video
Enclosure type
Jan 05, 2007 | Sony XS-L1200B Car Subwoofer
Audiofonics ADF-272 Car Speaker Logo
14 people viewed this question
Top Audiofonics Car Audio & Video Experts
Mark Skinner
Billy McCain
Billy McCain
Level 1 Expert
Bill Boyd
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
