Question about Square D 8910-dp32v14 Def Purpose Contactor 30amp 2pole
When my newly installed sqaure d 30 Amp definite purpose 120v coil pulls in it makes a loud humming noise. This noise is louder at times, and sometimes seems to make no noise and perform properly. The noise seems not to make a difference with or with out a load.
  • 3,740 Answers
Hi and welcome to FixYa I am Kelly. The humming your hearing is the contacts on the contactor relay. They are floating contacts. Due to the fact that they float depending on the position they closed in you may or may not get a hum. Over time it may or may not snap out of it as the contacts get some use wear on them. Usually they do. Sometimes they never do. It is not a bad thing unless you notice the contactor heating up. Often by the time you notice the heat build up it is too late. The heat build up is cause from loose floating contacts. There are springs above the contacts that hold the contacts together when the contactor is energized.
If your really believe that your contact is making way too much noice I would go to the purchasing source for your contactor and discuss your concern. They may or may not replace your contactor. It is a judgement call on your part. I would at least try cycling it on and off several times and see if it snaps out of it. If it never does.... go see the purchasing source and have a conversation about what your contactor is doing.
Thanks for choosing FixYa.
Kelly
Posted on Sep 11, 2010
MY 1998 FOR EXPLOYER ELT HAS A LOUD HUMMING NOISE THE FAST I GO THE LOUDER IT GETS CAN ANY ONE TELL WHAT A POSSIBLY CAN BE .MY HUSBAND SAYS THE SPINDLE????
Humming Noise Front End- Any Ideas? - Ford Explorer and Ranger ...
www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
Dec 18, 2008 - 19 posts - ‎16 authors
Have a 98- Eddie 4.0 SOHC, 4WD with a 100,000 mi. When driving it has a humming noise, it almost sounds like a bad tire, or a ... I start to hear the humming noise at 20 mph, it is very loud at 40 to 50 mph ... 94 XLT-95 FX4. humming gets louder as speed increases
May 27, 2010
How to: IAC valve cleaning thread (w/pics)
Oct 29, 2007
humming from air intake
Jun 6, 2002
Loud humming noise coming from the air filter
Oct 6, 1999
More results from www.explorerforum.com
Jan 12, 2016 | Cars & Trucks
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
My dodge stratus is making loud humming noise
Have the wheel bearings been checked?
Apr 25, 2013 | 2001 Dodge Caravan
Adcom gfa 7000 amp makes a cyclic humming noise in unit not in speaker
Are your grounds to BARE metal sounds like a ground loop issue.
Feb 25, 2013 | Adcom GFA-7500 5-Channel Amplifier
I have a Ruud AC Model UAMBO48JAZ That has started to have a hum when it is running it is cooling and has been checked for freon. Could it be the capacitor?
More than likely, it is the hum of the coil in the contactor. Generally, residential uses 24 volts to energize the coil built into the contactor which pulls in a set of contacts (hence the name contactor) to send 220 volts to power the compressor & condenser fan motor. Contactors are relatively inexpensive... so if the noise bothers you, replace it or have it replaced. Put your mind @ ease, the humming noise will do no damage.
Jul 27, 2012 | Ruud UAMB Air Conditioner
Every now and then, not often my 2001 grand marquis makes a loud humming noise while idling and it stops when i pull off, it may not do it again for another week. what is going on?
Hi and welcome to FixYa!
You may have a worn out pulley or tensioner somewhere on the engine. If the bearing of the pulley or tensioner is faulty it can make a humming sound during take off and will stop when parked. But in any given time it will break and will surely make much louder noise even when parked so you might as well have it checked and replaced if necessary.
Hope this helps and thank you for using FixYa! Have a good one!
Mar 03, 2011 | 2001 Mercury Grand Marquis
Have loud noise from engine,gets louder w/more rpms.it is an automatic,60k miles.no exhaust or muffler problem.
Serpentine belt tightener pulley bearing was bad, made a loud noise. I replaced the pulley (jobber part) and the noise level was reduced enough to notice the waterpump was also making a noise ... more revs = louder noise. I am now replacing the water pump. (approx 60k Miles too).
Nov 22, 2010 | 2004 Toyota Corolla
Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Jan 08, 2010 | Frigidaire GLD2445RFC Stainless Steel...
LOUD HUMMING NOISE
Here's my thoughts:
Make sure it is level.
Could be some things inside the fridge vibrating against each other.
Geno
Feb 09, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Square D 8910-dp32v14 Def Purpose Contactor 30amp 2pole Logo
128 people viewed this question
Top Square Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Square Measuring Tool and Sensor Expert? Answer questions, earn points and help others
