Question about Car Audio & Video
Car wiring diagram for JVC KD-R506 audio & speakers
This might help?
http://forums.justcommodores.com.au/car-audio/45638-jvc-headunit-wiring-diagram.html
Posted on Dec 28, 2010
Jvc kd s29
This is for a JVC KD-S29. Where can I get a wiring diagram for speaker, battery and ground from. Thank you very much.
Feb 01, 2013 | Car Audio & Video
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Jvc kd-g340 rear speakers not working. I recently bought the car with this unit installed. I noticed that there is a l/r cable, power, ground in the trunk which means there was probably a subwoofer...
check the wires in the back of the stereo if not then make sure the back speakers are not hooked up to a internal amp and if it is make sure that it is not blown
Mar 31, 2010 | JVC KD-G340 Car CD/ MP3 Player
I need a wiring diagram for a JVC KD-R805 installation
For putting it into what kind of car? Or did you mean the radio harness itself? Red is constant 12v, yellow is Accessory 12v, Black is the ground. Solid blue is power antenna, blue with a stripe is a 12v accessory meant to power the amp (AKA AMP REM), White is front left speaker, gray is front right. Purple is rear left, green is rear right and any of the white,gray, green or purple wires with a black stripe is the negative for that speaker. If you post a reply with a vehicle model and year I can give you the factory wire harness colors as well.
Jan 13, 2010 | JVC KD-R800 Car CD/ MP3 Player
I need a JVC KD-S550 wiring diagram for a 95 Saturn SC2
You do not need a wiring diagram....just go here and buy this harness, or purchase one at an electronics store. You will probably want to purchase an antenna extension adapter cable as well...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230398679871&crlp=1_263602_263622&ff4=263602_263622&viewitem=&guid=91c6dec71250a0aad5b65db6fc08aeec&rvr_id=&ua=WXF%3F&itemid=230398679871
Dec 14, 2009 | JVC KD-S550 CD Player
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
May 31, 2009 | JVC Car Audio & Video
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Car radio connections
Red wire to acc fuse
yellow= b+ fuse
blue= to amp amplifier
white= +left front speaker
white/black left front - front speaker
gray= + front right
gray/black= - front right
green= + rear left
green/black= - rear left
purple= + rear right
purple/black= - rear right
black = ground---to car metal
orange with white line to illimination
Apr 15, 2009 | JVC KD-G110 CD Player
Car Audio & Video Logo
615 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
