Question about Western Digital Computers & Internet
My WD external 500G hard drive is no longer powering up after being plugged in to the wall. The power supply 'box' is flashing a green light. It says the model number is ADS008. Can anyone help?
  • Western Digital Master
  • 27,725 Answers
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Posted on Sep 11, 2010
My power supply does not seem to be working.
You need the part number off the drive and contact western digital to get a replacement power supply if it is not in warranty.
May 06, 2010 | Western Digital Elements powered by WD 320...
My hard drive is not working, but I think it may be the power source because the green light on the transformer only stays on briefly when I plug it in. How can I be sure if that is the problem?
If you look at the Power supply box there should be a green light. If you unplug the cord and plug it in again it might just blink then stay our.. it is a common problem with these WD Elements. If it is newer, then it is under warranty.
How to check the warranty on a WD drive or product
Link: http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=915&p_created=1047361575
Title: What would void the warranty on my drive?
Link: http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=916&p_created=1048294698
If not they will sell you another one.
A replacement or extra power supply for your external drive can be purchased from our phone support team by calling 1-800-275-4932. Any technical support representative will be able to sell this part. Please have the serial number or model number of the hard drive ready, as this is needed to determine the correct adaptor type for the hard drive.
I hope this helps,
Randy
FixYa Support Team
Jan 04, 2010 | Western Digital Elements powered by WD 320...
I have a WD Elements TB external hard drive which has worked fine then suddenly today i plug it into my laptop i hear the bing bing noise but its not showing in my computer so I can't access it please help...
It is a common problem with power supply on these WD Elements drives. If it is newer, then it is under warranty.
I hope this helps,
Randy
FixYa Support Team
Oct 19, 2009 | Western Digital Elements powered by WD 320...
WD ELEMENT DOESNT POWER UP. GREEN AND BLUE LIGHT FLASHES
Have you contacted WDE.. by email,or, phone? Seems like that the hard drive has had its bios info corrupted , due to possibly hooking it up to the pc(in the wrong order), or even, a power surge that you were not aware of... The Manufacturer can send you a link to upgrade/restore the harddrive bios...
Sep 01, 2009 | Western Digital Elements powered by WD 320...
Something Dopped on maxtor 500G, Now not reading - making beep
two thing could be the power supply in the external box or it could be the drive it self
go to maxtor.com and download the software to test the drive
Aug 11, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
My WD Elements 640GB Wont turn on.
I had the same problem. I fixed this by leaving the power supply connected with the wall socket for about 15 minutes, without connecting it to the external hdd. After that I connected the power supply with the external hdd and it worked perfectly. I hope this helps for you too!
Aug 02, 2009 | Western Digital Elements powered by WD 320...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
500Gig HD Power Supply has Died - What can i do?
the power supply is probably dead. if its under warranty return it for replacement. if not under warranty have a local technician check the power supply.
Feb 13, 2009 | Maxtor Personal Storage 3200 (M1227310)...
Computers & Internet Logo
129 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
