Question about Samsung SCX 4521F All-In-One Laser Printer
My Samsung scx-4521 will not copy or scan anymore....I'm getting completely blank pages. It prints perfectly fine.
  • janice gooch Nov 20, 2011
  • 360 Answers
Hello this is a problem with your scanner unit. check it out. replace scanner cable.
Posted on Sep 11, 2010
Samsung scx-4521 all-in-one. Can print a test page that indicates I am connected to my Window 7. However, I am not able to print from internet. I have used the original install disc but will not install...
What version of W7 do you have, 64 or 32 bit? Did you chose the right version of software/driver? Please post here the error you are getting when SmarThru failed to install. Dan
Sep 22, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I have a samsung printer scx 4521. i did a format
You can download driver on this page:
http://www.samsung.com/ca/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=SCX-4521F
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 10, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Just brought my SCX 4100 into use in my office, worked perfectly at home on a Windows XP system but in the office on a vista system the printer works fine, the copy function within smart thru 4 functions...
Did you install the correct driver including the scan driver? The drivers are available at the Samsung Site: http://www.samsung.com/us/support/downloads/SCX-4100 . Click on the Driver tab for most or the Software Tab for the SmarThru4 program. Make sure to get the correct version for the OS on the office computer. Generic OS drivers often only run the printe, not the scanner. Uninstall the generic driver before attempting to nstall the Samsung driver.
Next check the data cable. Scanners require bi-directional communication with the computer and can fail when the printer works.
I hope this helps.
Jan 24, 2011 | Samsung SCX-4100 All-In-One Laser Printer
I hve the samsung scx 4521. and when i am trying to photocopy i am getting blank copy. and no content is coming. only i am gettting a blank white paper.. please give me a solution for this.thx
If the problem is coming only when coping thats mean there are few things that could gone wrong.The first thing to do is to check the scanner lamp.Open the top cover and press the copy button.The scanner should start moving and flashing.If the scanner is moving but no light i coming out of it means you scanner is broken or the cable(scanner-forrmater)is broken.If the scanner is moving and flashing but there is no image means the scanner forrmater board is broken.Please replay if you need futher help!!!
Nov 22, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Printout is black
please change your copier toner unite it demage
Aug 04, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
Samsung scx-4521 printer driver
try this site...then check the windows support when u download the driver
http://www.driverstock.com/Sapphire-SCX-4521-driver-download/19-26-4784/
Sep 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4521F All-In-One
If the lines only appear when using the top feeder, then theres probably white-out or something on the thin strip (called a slit glass) of glass on the left of the large glass.
If it appears when you put a document on the large glass, then it is another problem.
Jan 11, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung scx-4521 f
if it's a vertical line in scanned pictures, it's probably a dust bunny on the scanner head, if it's only on printed pages, it's probably a dust bunny on or in the laser assembly or between the laser and the photosensitive drum. if cleaning doesn't get rid of it, you could have a defective scanner head or laser assembly, or a scratch on the photosensitive drum.
Jun 27, 2006 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
537 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
