Question about GE GSL25JFPBS Side by Side Refrigerator
Have a ge side by side freezer is working fine fridge not getting cold. Evap coils were froze thawed it out and changed mother board thermisters and evap fan still not cooling?
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Sep 11, 2010
My freezer keeps going into intermittent thawing were the fan shuts off. I have checked the four thermisters and it appears that I am not getting a constant reading, but it does fluctuate near the 16
ge fridgs are hard to check.. but I have seen the main pcb cause exactly what is going on with your unit... if this unit has some age on it the pcb would be a good place to start.... does the evap fan run when u push in the fan door switch?? if not replace the evap fan motor at the same time.. it will save you a lot of headaches...... hope this helped....... ken
Oct 09, 2014 | GE Refrigerators
Refridgerator side not getting cold model gss201epaww
make sure the damper vent door located between the freezer and refrige compartments is opening and letting in cold air from the freezer,if they ice up they can stick shut and not allow air flow,this door is behind a plastic grille an a hair dryer works great to defrost them
Apr 30, 2010 | Refrigerators
Ge fridge not making ice I have water dis IT works fine I put one cup water in maker nothing could itbe the valva thanks
probably have frozen evap coil..turn off unit remove perishables leve refer door closed and freezer door open..thaw out for several hours..if you have a lot of water comming off you most certainly have ice up the coils..probably bad heater.defrost timer or board..good luck,RDS
Apr 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile side by side fridge - fridge not cooling/freezer fine
The problem you are having is what is called defrost. This unit is supposed to do a defrost every 8 hours. If it fails to do so the coils will get a heavy heavy frost on them and the evap fan cannot circulate the cold air thru the freezer and into the fridge. you will need to defrost the coils with a hair dryer. Will probably take about 45 min.'s to a hour. The most common cause for this is the defrost heater located at the bottom of the coils. Replace this and you will be fine to go. Part number is wr51x10101
Feb 24, 2010 | Refrigerators
Fridge and freezer not working
need more info, is compressor in back of fridge running ?
is the evap coil inside freezer froze up ?
is the fan inside freezer running ?
is the cond coil under back of fridge in need of cleaning ?
Sep 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE Profile Model PS123NG/PS123NS came brand
probably a loose thermister. The thermister being not attached to the evap coils tight might not be relaying back the proper resistances info for the control board to make a propper defrost determination.
May 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Coils in freezer freezing up
The defrost heater is bad . remove the back cover - defrost annd fix it.
May 07, 2009 | GE Refrigerators
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
GE GSL25JFPBS Side by Side Refrigerator Logo
245 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
