Question about Texas Instruments TI-84 Plus Calculator
Hi- on my Ti-84 plus Under STAT EDIT I do not have L1. It goes straight to L2 and so I can't graph anything.....any ideas on how to get my L1 back? thanks!
  • Texas Instru... Master
  • 7,993 Answers
Even if you do not have L1 you can still graph: You have 6 lists to put data in. You are not required to use L1 but you will have to specify the lists. Be it as it may you can restore L1, which in all likelihood you deleted.
Press the [STAT] key and select [4:SetUpEditor] then press [ENTER]
Posted on Sep 11, 2010
How do i get l1 l2 l3 charts up
L1, L2, L3?
If you are doing statistics, Set MODE to 3. Stat.
Choose 1-Var or any regression model. If you press 1-var you will have two lists x and frequency.
For any regression model you have 3 lists x, y, and Freq(uency).
L1, L2, L3, are list names in the TI 83/84 Plus and the Casio graphing calculators.
However I have no idea what getting the charts up mean.
I hope it helps
Oct 26, 2013 | Casio fx-115ES Plus Scientific Calculator
How to get l1 l2 l3 charts
L1, L2, L3?
I hope it helps
When i go to STAT then Edit the list that comes up are L2 and L4 and it goes up. How do i reset the functions back to L1 and L2.
Press STAT key. In the list of options that are displayed under the leftmost menu (EDIT) , press the 5:SetUpEditor. Press ENTER. It will restore the deleted list L1
Jun 12, 2011 | Texas Instruments TI-83 Plus Calculator
I want to enter in numbers for L1 and L2, but when I go the TABLE there is no L1 or L2 column, only X, and there are numbers entered in the X column that I want to delete. How do I clear the X values,...
The table is where the calculator displays values from functions entered in the Y= page. To enter numbers into lists, press STAT and select Edit to get into the list editor.
Dec 21, 2010 | Texas Instruments TI-84 Plus Calculator
How do I use stat plot to graph a set of points?
1.Press [MODE], scroll to set Function graphing mode.
2.Press [STAT] [5:SetUpEditor], command is pasted in home screen. Press [ENTER]. Screen displays Done. This clears old values in lists
3. Press [STAT][1:Edit] to enter data.
Press [ENTER] after each number. Cursor moves to next row. After finishing the data of Listt L1, use arrow right and UP to the head of list L2. Enter the values in list L2. Press Enter after last element.
4. Press [Y=] to display Y= editor. Clear function Y1 and all functions or remove highlight from the = in Y2, Y3, etc.
5.Press [2nd][STATPLOT]1 to select 1:Plot1
The blinking cursor on ON means graph will be drawn. Type chosen is Scatter plot. Mark chosen is a dot.
Press [ZOOM][9:ZoomStat]
If you think that the curve look like a straight line you can try to do a linear regression.
Press [STAT] Arrow right to highlight [CALC]
Select [4: LinReg(ax+b)]
LinReg(ax+b) echoes on run screen. Press [2nd] L1 Press comma, Press [2nd] L2 press comma Press [VARS] Arrow right to select [Y:VARs][1:Function] [ENTER][1:Y1]
68a28f1.jpgENTER
That is the equation for the linear regression. As you see eqaution has been saved in Y1. Press [GRAPH] to get the data and the regression curve drawn on same graph.
Hope it helps.
Oct 04, 2009 | Texas Instruments TI-84 Plus Calculator
Linreg
enter your data into L1 as x-coordinates and L2 as y-coordinates at (STAT) + (EDIT) and then turn on your StatPlot. Finally, press (STAT) ->(CALC) -> (4)LinReg(ax+b) and (L1) (,) (L2) (Y1)
nb: Y1 could be find from (VARS) -> (Y-VARS)->(1:Function...)
Apr 25, 2008 | Texas Instruments TI-84 Plus Calculator
Graphing assistance
it might be that your stat plot isn't set up right. when you hit second "y=" you should see under plot 1... Off L1 and L2. well you need to go to stat edit and see if they line up with the list you have. I hope this is what your talking about. sorry if i didn't help at all
Dec 17, 2007 | Texas Instruments TI-84 Plus Silver...
Graphing
Press STAT, go to Edit, then enter x values in L1 and y values in L2 (other lists can be used too, but these are the default ones).
Next, go to STAT PLOT, pick a plot, turn it on, select the type, data lists (x and y should be L! and L2 already; if not, change them), and mark type.
Finally, hit graph. You may need to adjust window settings to see all of the points. If you get a DIM MISMATCH error, check to make sure that there are the same number of entries in each list, and that only the plots that you are using are turned on.
Oct 25, 2007 | Texas Instruments TI-84 Plus Calculator
L2 disappeared
Here's what you do in a TI-83 or TI-84:
Go to STAT > 1: Edit > UP ARROW > 2ND > INS > *List Name* > ENTER
Hope that helps!
Oct 18, 2007 | Texas Instruments TI-84 Plus Calculator
Standard deviation
Here goes if you still need this...
STAT, EDIT, put information into L1 if only one variable stats, but put info into L1 and L2 if it is frequency table stats.
Then choose Stat, over to CALC, 1, enter...if 1 variable stats then press enter again. If frequency table stats, then choose STAT, over to CALC, 1, 2nd, 1 [L!], 2nd, 2 [L2], enter.
Oct 15, 2007 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
258 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
