Question about Soyo BayOne Extreme 9-in-1 USB 2.0 5.25" Reader/Writer () (960475040965)
How do i get the usb port to work on my soyo tv?
    Problem Solver:
  • 7 Answers
Go to set up screen and there should be options, USB should be under inputs or outputs, make sure it is highlighted "ON". Hope this helps, modern tv sets usually follow the same protocall.
Posted on Nov 30, 2013
How to change out the 3 HDMI ports on my Soyo flat screen TV model # mt-sytpt3227abms.
You would have to replace the tuner board or maybe just good reflow
Sep 29, 2015 | Soyo Televison & Video
Soyo bayone extreme vista 64 compatiable driver
The Soyo Bay one extreme doesn't need any specific driver, but you do need to make sure that the system usb drivers are up to date.
Feb 28, 2013 | Soyo BayOne Extreme 9-in-1 USB 2.0 5.25"...
When i plucg in my external hard drive it tells me that is will run better on USB2.0 ports. I thought the USB ports on the Soyo P4VGA mo were 2.0. please help.
even if the port is usb 2.0 is posible that the cable is not usb 2.0,
advice:
install chipset driver of mpther board and check whit other miniusb cable and see if is the same problem
best regards
Sep 22, 2011 | Soyo SY-P4VGA Motherboard
Need motherboard manual for soyo k7v dragon plus
SY-K7V DRAGON Plus! - SOYO
AMD Socket-A Based VIA KT266A Chipset ATX Motherboard
AMD Recommended Motherboard
D: DDR266 SDRAM
R: Promise IDE-RAID (0,1)
A: CMedia 8738 6-channel hardware audio on board
G: Universal AGP Pro slot
O: Overclocking, set up FSB by 1MHz increment
N: 10/100 Mbps Ethernet by ICS PHY Controller
Specifications
Processor
Click here for maximum CPU support
Click here for maximum Front Side Bus (FSB) support
Interface
Socket "A"(462)
Chipset Type
VIA KT266A
Chipset Description
VIA KT266A / 8233 CE Version Chipset
Supports 200/266 MHz FSB
Form Factor
ATX
Memory Type
DDR SDRAM
Memory Description
Three DDR 2.5V DIMM sockets support up to 3GB*.
184-pin PC2100/PC1600 non-ECC, unbuffered DDR SDRAM memory.
*recommended to use 3 sticks of DDR200(PC1600), or 2 DDR266(PC2100) memory on this board.
Expansion Slots
Five 32-bit Bus Mastering PCI slots (V2.2 compliant)
One Universal AGP Pro slot (supports 1x/2x/4x modes)
Expansion Slot Types
IDE Type
UDMA 33/66/100
IDE Description
Four independent channels for 8 IDE devices (2 for RAID)
Supports up to PIO mode 5 & Ultra DMA 33/66/100
Two PCI bus mastering ATA E-IDE ports
Audio Description
On board CMI 8738 audio chip providing 6-channel audio solution
IO Port Description
Two RS-232 serial ports (16550 UART compatible)
One parallel printer port (SPP/EPP/ECP mode)
One FDD port (supports 3 modes, 1.2/1.44/2.88MB FDD)
Provides IrDA with optional cable for transceiver
Provides 6 USB ports (2* rear, 4*front)
IO Connection Description
PS/2 Mini-DIN mouse & keyboard ports
Two USB ports
One RJ45 connector
Two D-Sub 9-pin male serial ports
One D-Sub 25-pin female printer port
Audio I/O: LINE-OUT x 1, LINE-IN x 1, MIC JACK x 1
One game port
BIOS Description
Award PCI BIOS with ACPI function
Supports multiple-boot from E-IDE / SCSI / CD-ROM / FDD / LS120 / ZIP
2 Mbyte Flash ROM
Health Monitoring Description
On board voltage monitors for CPU Vcore, +3.3, +5V & +12V
CPU fan speed monitor
CPU temperature monitoring through flexible thermal sensor
Dimension Description
Four layers, 30.5 cm x 23 cm (12" x 9.05")
ATX form factor
Certification
FCC Class B & CE EMI Regulation CompliantPC99 Compliant
Compatibilities
WinXP / Win2000 / WinNT / WinME / Win98SE / Linux / FreeBSD
Warranty
All SOYO products are designed to offer stability and flexibility, and are tested to ensure highest reliability. We offer a 1 year limited warranty on this SOYO product.
CPU Support
Compatibility
RAM Memory Support
Compatibility
Manufacturer - downloads drivers, manuals and BIOS : SOYO
Prodejce v èR : Mo?nost vlo?ení odkazu prodejce - info zde
Recenze : Odkazy na recenze vlo?íme po dohodì
Problems, experience, griffs.....:
Jun 06, 2010 | Computers & Internet
Soyo SY-P4I845GVISA Plus will not see USB keyboard
Go to the setup program and enable the "Legacy USB Support".
Nov 03, 2009 | Soyo SY-P4I 845PE Motherboard
I need a remote for a soyo 32 inch tv or a code that works with a universal remote
The RCA RCR312wv sold at Wal-Mart for about 7 bucks has 2 SOYO codes and the second one worked on my 32" SOYO
Oct 27, 2009 | Soyo DYLT032D 32 in. LCD Television
I need the pin-out for the USB 3-4 and 5 ports on the Soyo SY-K7ADA V1.0
Here's the manual: http://www.motherboards.org/files/manuals/107/mk7ada12.pdf
Pages 5 and 29 give very detailed pinouts.
Essentially:
_ 4 3 2 1
10 9 8 7 6
-Jon
Sep 25, 2009 | Soyo SY-K7ADA Motherboard
I need the manual for a soyo sy-kt400 dragon lite motherboard
Hi freebird2k6,
Go to this Soyo link:
http://www.soyousa.com/content/Downloads/155/&c=35&p=173&l=English
Drivers, bios & manual located on this site.
Manual is at the bottom of page. (Soyo no longer supports the board so download everything & burn it to CD).
Soyo may stop listing these drivers soon.
Mike
Dec 31, 2008 | Soyo SY-KT400D DRAGON Lite Motherboard
USB HD not responding
why dont you format it, so that you can use it nicely!
Mar 31, 2007 | Soyo USB Hard Drives - 20GB...
Televison & Video Logo
53 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
