Question about Hitachi Televison & Video
My hitachi 32ld8d2ou a the problem is it dont switch on check fuses inside and in plug
2 Suggested Answers
  • 360 Answers
SOURCE: not getting power to ac clutch. have checked all fuses in both fuse boxes i want to know if there is an inline fuses of a relay switch from the inside switch to the power plug to ac clutch
on the suction side (low pressure) of the system there is a pressure switch that prevents the system from operating in a low freon condition. Get a set of gauges on the system to check for a low freon condition...Bypassing the pressure cutout switch could (and normally does) result in major system damage (destroys the compressor).
any questions, let me know.
clarkco
Posted on Apr 30, 2009
Driver door all switches dont work
First I would check the fuses and relays. If power is going to your door switches then the connections are corroded. Just clean them and see if that works. Good luck
Apr 09, 2017 | Cars & Trucks
Toshiba 19BL502B wont switch on
On the main power board inside the TV there are fuses take a look at them and the transformer and capacitors for damage
Dec 15, 2013 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
Tv wont turn on
Check the ff:
1. Power plug - for open internal wire due to frequent bending,pulling.
2. Try to power by remote - if power up by remote then you have a faulty tack switch.
3. Replace Internal Fuse - sometimes because of power surge the fuse fail. However if the fuse blew again this is an indication of shorts.
Next step is not Diy because of the ff reason
3. Voltage regulator - might be open or shorted.
4. H-out transistor - shorted
5. Open fusible resistor in line with the B+.
6.Dry joints
Thanks for using fixya.
Pls rate my help.
Jan 25, 2011 | Hitachi Televison & Video
37" hitachi plasma tv doesnt turn on
If you have a light on ( standby light ), then I would say power supply fault, tv could be shut down because of faulty capacitors in power supply. if you dont have any lights at all , check fuse in plug,
( there will almost certainly be a fuse in the tv) but, that is for a tv guy to fix.
pete
Nov 10, 2010 | Hitachi 32HDX60 32 in. Plasma Television
Hitachi projection TV does not power up
You probably have a blown 2kV capacitor and 2 amp fuse. Look for signs of black burning inside.
Aug 09, 2009 | Hitachi 50UX57B 50" Rear Projection...
MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Its dead no led on switch on and no picture
Yes it has a AC fuse you can check it but I have not seen one the was open. I think your problem is in the SMPS.
May 18, 2009 | Hitachi 42 in. Plasma TV
Green leds turn on momentarily when first plugged in then shutoff
ok , on hitachi pro tv is very common with bad power supply u may want to replace the voltage regulator which is next to the fuse u already replace , also loose connection on all the power supply seccion , also u may want to check the resistor close by the convergence ic 2.2 ohn if this are smoke replace stk392-110
May 07, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
