Question about Moyer Diebel 24 in. 501HT Built-in Dishwasher
When we close the door and put switches on, only the temp light comes on. nothing else happen. Thanks
    Problem Solver:
  • 40 Answers
Could be the switch marked delime is in the on position.. That switch should be in off position. (pushed in at bottom)
Posted on Feb 13, 2014
Press START and nothing happens
yes the door has a safety switch that will keep the machine from starting, this is most likely the problem.
Aug 12, 2008 | Kenmore 15762 Dishwasher
Bosch Dryer WTL 5410 UC do nothing after selecting a program and hitting the start button. The only thing that happens is that the Drying light lits and nothing else happens. I have tried to hit start...
Door switch may still be your problem. Mine showed lights as if working when closed but I decided to use a screwdriver and push in switch all the way in. It worked then without door closed. It will stay stuck until you pull it own a bit to release it. Give it a try. The door switch appears to have two switches in it requiring it to be all the way in.
Aug 12, 2011 | Bosch Axxis WTL 5400 Dryer
Lift master door will not close with remotes. to close door, the main switch in garage has to be held down until door reaches bottom. when using either remote or main switch, to close said door, the...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is lit and not flickering. Tweak them a bit. Check the wiring for breaks or shorts. Nothing else will cause this problem.
Dec 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
My microwave lights blinked off right after i closed the door after checking meal and re-entering time. i unplugged it and tried a different socket nothing happens no sound lights for time or inside the...
I suspect the interlock monitor switch in your microwave oven is the culprit. This is one of several switches operated by the door latches. It's designed to blow the fuse if you try to run the microwave with the door open. The switch is probably stuck, or is out of adjustment (which can happen if the oven door gets closed hard), and when you restarted the oven it blew the fuse. It is possible to adjust or replace the switch as necessary, but it might not be worth it. You should have a professional do the repair as there's a chance of microwave leakage if repairs involving the door aren't done properly. Between labor and parts, the repair cost might come close to (or even exceed) the replacement cost for a small oven.
Hope this helps, and thanks for using Fixya!
Nov 09, 2010 | Emerson MW8778 Microwave Oven
I have a Kenmore Elite Dryer, Model # 11061066000 and nothing happens when you touch the buttons on the control panel. Light inside works. Any solutions? thanks.
there is a thermal fuse mounted on blwer housing w/2 blue wires coming to it,thats a popular fix...also check that the door is activating the door switch when closed....its usually one of the 2
Mar 10, 2010 | Dryers
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Brake lights come after car locked on audi a4 s line 05
I HAD THE SAME PROBLEM, MINE HAPPENED ONLY WHEN THE CAR WAS COLD (OUT SIDE TEMP) 2to3 HRS. AFTER PARKING,OUTSIDE TEMP 32F OR LESS. I REPLACED THE BREAK LIGHT SWITCH THIS FIXED IT.
Jan 10, 2009 | 2005 Audi A8
Don't know what is going on
Check the door lamp switch & lamp pwr switch, boss on the door or lamp assy may not close switch. apply tape to boss
Mar 15, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
May 09, 2007 | GE JE1540 Microwave Oven
Moyer Diebel 24 in. 501HT Built-in Dishwasher Logo
43 people viewed this question
Top Moyer Diebel Dishwashers Experts
Owen Barnes
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
