Looking for manual for bose model 360 turntable
BOSE 360 turntable manual
go google and type in --bose turntable spares --- and get a site that says spares like bose .com.au>en_au>support
or sansui-parts-shop.com
call on the phone or e-mail on the contact address
Jul 03, 2016 | Audio Players & Recorders
I have a Stanton T60, but I connect to my Bose, but my bose has no phono input, tried aux but low volume... Do I need to buy a preamp?
You don't need a PRE-amp but you do need an amplifier. The auxiliary plug on the Bose is only for iPhones etc which have a margin of their own amplification which your turntable has none. The phono plugs are for the turntable to supply a low power signal to the amplifier to boost it to be audible at volume.
Oct 06, 2015 | Stanton Audio Players & Recorders
How to install grounded turntable to bose lifestyle without a hum
Try disconnecting the ground to see if the problem goes away. There may be a ground loop created by connecting the devices.
Oct 23, 2014 | Bose Audio Players & Recorders
Turntable manuals
I seriously doubt you will find one, as Yorx is a small Asian company. Are you looking for a service manual or owner's manual? For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 01, 2013 | Audio Players & Recorders
I need to to hook up my turntable to my bose system
As long as the Bose has a spare audio socket you can do it. You however will need a device called a "Magnetic Cartridge Preamp". Otherwise all you will hear is the sound at a very low level.
Feb 10, 2013 | Panasonic Technics SL-BD22D Turntable
I would like to add a turntable to my Bose Cinemate II but when i plug the RCA directly into the Bose module the volume has to be to the max and is still very quiet
You need a preamp to solve that problem, the older amps and receivers had built in phono inputs with a preamp stage. Radio Shack use to make a preamp that ran on a 9volt battery for turntables that ran into the very problem you are talking about. But I do not know if they are still available, go to www.ebay.com Type: turntable or turntable preamp
Apr 07, 2012 | Bose Cinemate Digital Home Theater System...
What is the best turntable/speaker system for the money? I have a lot of LP's that I would love to play, my old Sansui system was too cumbersome and now I want a good, more compact turntable system. ...
Have a look at the hi-fi magazines. They have plenty of reviews of them.
Or you can just do an Amazon search and select by customer reviews. I tend to to do this with all electrical stuff anyway. Even if I don't buy from Amazon. The customer reviews, when in large numbers can give clues to how good or reliable anything is.
Jul 18, 2017 | Bose Wave Music System CD Shelf System
Adding turntable to bose music wave system
Hiya, sad to say it wont work even with the correct plugs. If you really need/want to get it going, you will need a RIIA pre amp to use to convert the turntable levels to an acceptable level for the bose. Once you have that, then get the correct matching plugs for the bose (sames guys that supply the preamp should be able to help). Suggest a google search in your area "RIIA PREAMP" and see who supplys.
Best of luck
Jul 15, 2009 | Bose Wave Music System CD Shelf System
Question on Bose 3-2-1
hi! you can hook up .. first if your bose amplifier have a phono input you can put it plug and play. but if no pre amp phono input you have to buy or provide (from turntable to pre-amp phono to bose)  to heard and listen to your old vinyl.. mk2 batallion.....
Feb 24, 2009 | Bose 3·2·1 II System
208 people viewed this question
 Grubhead
Grubhead
