I want to buy a new hard drive for my panasonic DMR-EH55 dvd recorder, but I don't know where to buy one, any sites as a suggestion??
    Problem Solver:
  • 11 Answers
You'll get your best deals on eBay. Any brand 200 GB hard drive will work.
Posted on Sep 11, 2010
My dmr-eh55s will no longer transfer from the hard drive to the DVD in the high speed mode. It will in low speed mode (real time).
It sounds like the DVD-RAM drive is about dead. Panasonic did not make them to be very durable.
Panasonic sells replacements at a high cost.
Replacement drives may work from used models including:
DMR-ES15
DMR-ES25
DMR-ES45
DMR-ES46
Jun 17, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
Need the Panasonic DMR-EH55 remote control code for a universal remote
Different Brand remotes use different codes for devices. Usually you can find web sites for your particular brand remote and get codes there.
Feb 27, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
DMR EH55+ a misdiagnosed problem
The DVD Drive is bad. Buy a used DMR-ES15, DMR-ES25, DMR-ES45, or DMR-ES46 with a good DVD drive and swap out your bad drive. And be sure not to record in the high speed mode in the future. Set your recorder to High Speed Mode Off. Then see about getting your money back from the shop that didn't know what they were doing.
Mar 25, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic DMR-EH55 Ram Drive Problem
Do you mean you want to replace the hard drive in the unit? If so, I have one of these units and I installed a new PATA hard drive and then "prepared" it with a firmware update that is available from Panasonic's website. I tried to increase the capacity by installing a 500GB hard drive, and also a 300GB hard drive, but no matter what size I put in, after I initialized the new hard drive with the firmware disc I always only had 92 hours available to me. In fact there was never anything wrong with my unit, I was only trying to increase the capacity for recording - which I was never able to do. I did find that another 200GB hard drive I tried didn't actually work for some unknown reason, but the 500GB, the original 200GB and a 300GB hard drive worked no problem every time I swapped them around. Let me know if you need the link to Panasonic's download - it's easy to find.
Jan 23, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic DMR-EH55 Ram Drive Failure
DMR-EH55 HDD ERROR
Can you be a bit more specific? You cannot read the TV guide, instructions and other data or only the list of programs you ahve recorded?
Jun 07, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Hard drive out, can't start up with new one
I know this is an old post but I wanted to share my success with others. I have been successful in changing the hard drive in my Panasonic DMR-EH55. It was very easy once I had the firmware disc which I downloaded from Panasonic's website yesterday. Had been looking for months for a way to do it and finally it came through. The firmware disc image is just over 7MB and the file is named dmreh55_up317.zip - I downloaded it from panasonic's website at http://www.panasonic.ca/pdp/software/dmreh55_up317.zip
I hope this helps out as it did for me.
May 28, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
DMR-EH55 DVD recorder is not able to read DVDs any more
You purchase a dry DVD lens cleaner and put it inside the tray. It will clean it for you. If you take apart the drive to expose the lens, you are actually at risk of making it worse.
Mar 08, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
Top Televison & Video Experts
